Hi
This is an archive I just made
As it is a French site to share files a few explanations may be useful.
You should see an icon named DEMODRM.RAR
You click on its top red button and should see a small menu the key word to select
is telecharger that means download.
It should be rather fast but it is a big file about 300MB
Inside the archive you have a player "Sodira " it is German but the buttons are in English.
Information can be found here:
The only thing you should need to configure is your sound output.
Then on the main window you press play and select the big *.WAV file
If Gods are on our side you should be able to explore 96 Khz of the French MW band
as it was at the date of the file.
I hope it will work as I have little use of this sharing site and no experience of using it
world wide.
world wide.
