BBC WS & RTL using AMSS (AM signaling)
  • Filter
  • Time
  • Show
  • DRM-Fan
    • Jun 2003
    • 209
    #16
    Thanks Roland though now have a complited version downloaded from a certain website I had partially forgoton about 1.5 CVS.
    THe AMSS decoding is amazing as I'm barely getting BBC WS on 648 but the AMSS data shows 100%! I hope more station adopt this system
    DRM radio. New yahoo group for all owners of DRM radios - Please join at :- http://groups.yahoo.com/group/alldrmradio/
    • dk8cb
      Roland
      • Mar 2004
      • 2748
      #17
      Originally posted by jbriggs
      ... However this could cause confusion for a receiver trying to demodulate the phase information from the main carrier because it will be varying in amplitude too due to the DCC.
      Since the information is entirely in the phase of the signal, if I understand it correctly, wouldn't it be sufficient if the receiver just limits the received signal at a sufficiently low level as any FM receiver does? You can easily achieve 60 dB of AM suppression this way. Shouldn't this be sufficient to get rid of any amplitude variations generated by carrier control and/or fading?
      Roland
      • dk8cb
        Roland
        • Mar 2004
        • 2748
        #18
        Originally posted by DRM-Fan
        So RDS for AM then.
        You could term it that way. Similar systems have been used for a long time to transmit data along normal programmes. To my knowledge, Droitwich, now transmitting on 198 kHz, formerly on 200 kHz, carries a phase modulated time signal using a similar system. Radio-controlled clocks make use of such phase modulated transmissions from longwave transmitters (MSF, DCF77) to obtain accurate date and time information.
        Roland
        • jbriggs
          James Briggs
          • Aug 2002
          • 148
          #19
          Roland this sounds like a valid approach, maybe the receiver manufacturers won't need to use this extra information. But the approach to take is up to the receiver designer.
          Forum Administrator
          • Andreas
            Junior Member
            • Jul 2005
            • 215
            #20
            As reception of 234 kHz is impracticable at my QTH due to an yet unidentified source of hum I tried 648 kHz instead.
            Yes it works!
            Edit: But it takes some time on 9410 kHz. AMSS acqusition requires exact tuning by hand to the centre of the carrier. However data are lost repeatedly....
            • Andreas
              Junior Member
              • Jul 2005
              • 215
              #21
              I must correct myself:
              Although I would rate received audio with O= 1 AMSS works also on 234 kHz from Luxemburg. It's amazing!
              But still no success with 941o kHz although audio there is - let me say O=4 to 5. Mhmmmmm ????
              • dk8cb
                Roland
                • Mar 2004
                • 2748
                #22
                Originally posted by Andreas
                ... But still no success with 941o kHz although audio there is - let me say O=4 to 5. Mhmmmmm ????
                I had the same effect yesterday. When I tried in the early evening, it worked perfectly on 9410 kHz despite a weak signal. When I tried again later, this time with a strong signal, it didn't work. I guess, different transmitters at different sites are used at different times of the day, one using AMSS and the other not using it.
                It works very well at the moment (2115 UTC) and there is no need to position the cursor precisely, I always let Dream do it by itself, see settings in my screenshot (Auto frequency acquisition and PLL).
                Roland
                • radiomann
                  • Jun 2003
                  • 297
                  #23
                  Maybe a silly question but how come I have no AMSS on Dream?
                  Paul
                  • dk8cb
                    Roland
                    • Mar 2004
                    • 2748
                    #24
                    What is your version? AMSS has only been implemented last saturday on version 1.5, you won't find it on older versions.
                    Roland
                    • radiomann
                      • Jun 2003
                      • 297
                      #25
                      Roland
                      Hi Roland,
                      I downloaded version 1.5 today all I see is a DRM button?
                      Paul
                      • dk8cb
                        Roland
                        • Mar 2004
                        • 2748
                        #26
                        Now I see clearer, you mean you downloaded an executable today and you now miss the AMSS button in your version. Well, the screenshot is taken from an even newer cvs version which I compiled yesterday. On your version, AMSS can be activated via the settings menue, if I remember it correctly.
                        Roland
                        • simone
                          simone
                          • Jan 2003
                          • 10144
                          #27
                          Hi Paul,
                          just click on settings and choose AM and the AMSS window will be opened.
                          Simone
                          • dk8cb
                            Roland
                            • Mar 2004
                            • 2748
                            #28
                            Originally posted by simone
                            Hi Paul,
                            Simone
                            Now I remember that on my first try with the previous version, I also did not see the AMSS window because it was located behind the AM window. Just move the AM window a little to the side and you will see ...
                            Roland
                            • DRM-Fan
                              • Jun 2003
                              • 209
                              #29
                              So can we expect to see AMSS implemented next year as DRM radios become available which have this 'built in' to the spec like the Roberts RD20 ? I'm thinking of course also an excellent tool for MW dx'ing but I guess it will never become common place...or will it ?!
                              • radiomann
                                • Jun 2003
                                • 297
                                #30
                                Thanks Roland & Simone, it was hidden behind the other window.
                                Paul.
