Old 25-08-2018, 18:40   #1
f1tay
Unknow 4770 kHz
Fort signal DRM sur 4770 kHz à 18h15.
Indication :
DRM SERVICE A
Pas d'audio juste du data.
Old 25-08-2018, 20:20   #2
KiwiSDR direction finding via TDoA puts the transmitter somewhere in the Alps of SE Switzerland near the border of NW Italy at approximately 46.35 deg N, 9.70 deg E.
34°02' N, 84°24' W
Old 25-08-2018, 21:02   #3
Yes I receive signal of S/meter S9+20 db no audio, SODIRA audio codec CELT !!! :
https://nsa39.casimages.com/img/2018...5001555890.jpg
https://nsa39.casimages.com/img/2018...5034388289.jpg
Old 26-08-2018, 00:37   #4
Noted, via a KiwiSDR near Wilhelmshaven, running some sort of data service using half the channel at 00:05 UTC, 2018/08/26.
Old 26-08-2018, 02:00   #5
Interesting, 'cos at the time I was trying to DF the signal the spectrum looked like normal 10 kHz DRM.
Marcel's SODIRA scan also shows a normal type DRM signal but perhaps 9 kHz or a little less wide.
34°02' N, 84°24' W
Last edited by AF4MP : 26-08-2018 at 02:03. Reason: added "but perhaps 9 kHz or a little less wide"
Old 26-08-2018, 02:10   #6
In fact Marcel's screen ID does show B/10 kHz as the Mode/Bandwidth (see attachment).
34°02' N, 84°24' W
Old 26-08-2018, 02:15   #7
They were 10 kHz bw until 00:00 UTC, then 5 kHz.
Also noted on KiwiSDRs in Sardinia & Ireland.
Old 26-08-2018, 02:27   #8
Although the KiwiSDR TDoA shows the transmitter location as Switzerland, the Principality of Liechtenstein is only 30 or so kilometers to the north and close enough to the DF circles, to make that country host to the transmitter site!
Vaduz, the capital of Liechtenstein, is known as a big financial center is only 80 km from the DF'd location.
34°02' N, 84°24' W
Old 26-08-2018, 14:44   #9
f1tay
Peut être Berne Radio à Prangins 46°24'24" N 6°15'4" E ?
Daniel
Old 26-08-2018, 14:56   #10
f1tay
D'après ce site : http://www.utilityradio.com/stations...sui/sui-63.htm
Bern Radio utilisait en télétype la fréquence de 4764,7 kHz soit à -5 kHz de 4770 kHz..
Old 26-08-2018, 20:01   #11
Aug_26
I got a label on 4770kHz from Kuwait.
Old 27-08-2018, 16:41   #12
16H10 UTC I have DRM signal of 4770 Khz.
Old 27-08-2018, 18:55   #13
DRM Hdn
DRM Hdn's Avatar
Unknow 4770 kHz
Signal also visible here but no chance to decode it. Very interesting is only 5 kHz is sending out...
Old 27-08-2018, 19:08   #14
DRM Hdn
DRM Hdn's Avatar
Unknow 4770 kHz
see the attachments
Old 27-08-2018, 19:26   #15
Hallo Hdn,
Alles wie bei mir.
https://nsa39.casimages.com/img/2018...1510381188.jpg
