Old 27-08-2018, 07:23   #61
Yesterday arround 21H00 UTC I hear poor signal DRM of 6030 Khz,is very good.
I think that with the approach to the autumn the signal will still rise and I could decode the DRM of China. At the moment I had not heard this signal and the I am very surprised.
Old 27-08-2018, 23:01   #62
Best reception so far from China. 20% decoded audio and the SNR peaked around 16,6 dB.
Old 29-08-2018, 00:44   #63
Voice Of China with a regular test broadcast aimed for China logged for 142 minutes from 1033-1255 UTC. Max.24 dB SNR and 12,73% decoded audio.
By the way, the audio was back to normal again on the 27th and the 28th. Very good audio.
Old 31-08-2018, 02:43   #64
Voice Of China with a regular test broadcast aimed for China logged for 196 minutes from 1022-1338 UTC. Max.25 dB SNR and 5,86% decoded audio. Did they change the Label? The Bitrate is of course not correct, but that is what the log said.
Old 31-08-2018, 07:39   #65
I was very Happy yesterday evening I receive CNR only of screen poor signal no audio, is very good reception for my strong fading SNR from 0 to 7 db :
https://nsa39.casimages.com/img/2018...1916382679.jpg
Old 01-09-2018, 01:12   #66
Voice Of China with a regular broadcast aimed for China logged for 202 minutes from 1027-1350 UTC. Max.26 dB SNR and 11,97% decoded audio. They did not change the Label, this was caused by GR-216 for some reason. The ANSI code (Notepad) was the same as last night but a test this morning with DReaM proved that the Label was the same as always.
Old 01-09-2018, 12:39   #67
Tonight's log. 23,3% decoded audio with DReaM. CIR is flat as a pancake.
Old 02-09-2018, 00:13   #68
Voice Of China with a regular broadcast aimed for China logged for 211 minutes from 0903-1234 UTC. Max.22,48 dB SNR and 23,3% decoded audio.
Old 02-09-2018, 13:22   #69
A log taken with DReaM V2.1.1. Note that when I stopped the log and switched to DReaM V1.6.1 I got decoded audio immediately. Dream V2 etc is not my choice.
Old 03-09-2018, 07:28   #70
Retour from Voice of China to my report :
Dear Marcel,
Greetings from Beijing. Thank you for your attention.
Since 23rd Jul. test DRM on 6030 kHz became a regular test transmission. The schedule is 2025-1805 UTC. It is just a domestic broadcasting test. We have already updated the requirement into B18 HF broadcasting schedules. And in the test period, the normal AM transmission on 6030 kHz will be shut down.
We are planning to upgrade several transmitters in this year. In the near future, there may be more and more test DRM transmissions. Looking forward to your attention and feedback.
Please feel free to contact us.
Best regards.
Sincerely
Sun
Old 04-09-2018, 00:23   #71
I got exactly the same message in the mail yesterday. Last Sunday I asked them if there would be additional transmissions on other frequencies.
I have a problem with the DReaM V 2.1.1 - I am not able to register the faad... dll under Windows 10 pro. Instead I used the V 1.6.1, but this one won't accept the Kanji characters in the .txt file. But the reception was not too bad last night.
Voice Of China logged for 146 minutes from 1030-1257 UTC. Max.21,99 dB SNR and 27,69% decoded audio.
Old 04-09-2018, 03:12   #72
NZ log of 6030 kHz from September 3rd.
73 Chris
Old 07-09-2018, 02:39   #73
6th Sep.
Voice Of China with a regular broadcast aimed for China logged for 182 minutes from 1033-1335 UTC. Max.19,17 dB SNR and 16,83% decoded audio.
Old 10-09-2018, 00:37   #74
9th Sep.
Bad reception. Voice Of China with a regular broadcast aimed for China logged for 173 minutes from 1118-1411 UTC. Max.14,58 dB SNR and 1,28% decoded audio.
Old 11-09-2018, 00:09   #75
Voice Of China with a regular broadcast aimed for China logged for 223 minutes from 0938-1322 UTC. Max.21,84 dB SNR and 14,32% decoded audio.
