Old 13-07-2018, 11:16   #1
China National Radio on 6030 kHz
found this news on DXLD mailing list, posted by Ron Howard from California:
CNR was heard in DRM on 6030 kHz at 0647 UTC with traditional music. See this link for more: http://radio.chobi.net/DX/bbs/?res:731#3351
Old 18-07-2018, 13:57   #2
alokesh
CNR (China National Radio) will be having DRM tests on 6030 kHz, 24th July onwards at 0100-0800 UTC
Alokesh Gupta, VU3BSE
New Delhi, India.
Old 23-07-2018, 14:28   #3
According to some insider info. The schedule is from 20:25 to 18:05 (UTC). Main service area is North East China. Central and East China should also get good coverage.
Old 24-07-2018, 00:48   #4
No signal here in Japan because it is broad daylight here at the time of writing (00:20 UTC). I received a weak signal around 0010 UTC with a 0-30 MHz Kiwi SDR at Shenzhen, China. The SNR at that location was about 4-5 dB and no audio.
Mode B / 10 kHz
Interleaver: 400 ms
SDC/MSC: 4/16
Protection: 1/1
Audio: 1/0
Time/Date: Tue Jul 24 08:11 (Chinese local time!)
File Type: jpg 6030kHzTitle24.07.2018@0011UTCfrom ShenzenKiwi.jpg (24.9 KB, 257 views)
Old 24-07-2018, 03:02   #5
Digital shortwave done right! Wow!
Now, xHE-AAC please, and possibly a better frequency in the 25 or 31 meter bands.
Old 24-07-2018, 07:12   #6
No signal in Northeast FRANCE around 2018.24.7 at 5H00 UTC
Old 24-07-2018, 10:54   #7
Some signal seen here in Shizuoka now around 1030 UTC. Around 7 dB SNR and a steady label.
I'll report later.
Old 24-07-2018, 22:34   #8
Originally Posted by zfyoung
According to some insider info ...
Any information of the location of the TX site?
Old 24-07-2018, 22:43   #9
My two logs from last night in central Japan. The first log is 2 hours 40 minutes and the second is 3 hours 38 minutes long. There were only a few fragments of decoded audio. The transmission seems to be a mix of talk and music.
Old 25-07-2018, 00:55   #10
The tip-off did not provide the info. about the Tx location. On the other hand, you can detect the whereabouts by conducting HF direction finding via KiWi TDoA. Some enthusiast has applied that technique and successfully captured the CNR Tx site in AM mode.
Old 25-07-2018, 01:36   #11
... the whereabouts by conducting HF direction finding via KiWi TDoA.
I found a Chinese SDR at OM88co (Hebei), but soon after I started logging it disappeared and now it's no longer on the list at sdr.hu. Grrr.
Old 25-07-2018, 05:21   #12
China DRM 6030 kHz
HFCC lists 6030 kHz Beijing , China, with 100 kW to an omni directional antenna.
Inputting these parameters into VOACAP shows a good signal into Japan from 1000 - 2200 UTC. However HFCC listed transmission time is 2025 - 1805 UTC.
Christopher on the DRMNA Forum reported a marginal signal (no audio, but screen ID) at 1430 UTC on the NW coast of the USA which agrees with VOACAP prediction.
Last edited by AF4MP : 25-07-2018 at 18:37. Reason: Added transmission time, edited typo.
AF4MP is online now   Reply With Quote
Old 25-07-2018, 08:23   #13
alokesh
Received at 13.00 UTC CNR DRM test transmission on 6030khz via SDR receiver at RU/ROCCN (Russia, Khabarovsk) with several audio interruptions.
Dream
Software Version 2.1.1-svn808
Starttime (UTC) 2018-07-24 13:04:19
Frequency 6030khz
Label 中中中中
Bitrate 14.56 kbps
Mode B
Bandwidth 10 kHz
MINUTE SNR SYNC AUDIO TYPE
0000 13 150 604/05 0
0001 16 150 663/05 0
0002 12 5 20/00 0
0003 15 76 303/05 0
0004 15 150 623/05 0
0005 12 89 288/05 0
0006 13 63 233/05 0
0007 16 135 592/05 0
0008 16 150 703/05 0
0009 16 150 706/05 0
0010 16 149 708/05 0
0011 16 150 661/05 0
0012 16 150 633/05 0
0013 15 150 643/05 0
0014 15 150 537/05 0
Benjamin
(Via email to me)
New Delhi, India.
Old 25-07-2018, 13:30   #14
My log from this evening: Max. 13,57 dB SNR and 2,94% decoded audio. An audio snippet is enclosed. Only a few seconds because of the size limitations of this Forum.
The title in the Gospell became "????". Any comments?
Old 25-07-2018, 18:44   #15
KiwiSDR TDoA China 6030 kHz
Just tried out the very neat KiwiSDR TDoA direction finding feature on the China 6030 kHz transmitter.
Using fixes from 1 Russian, 2 Japanese, and 2 Chinese KiwiSDR web receivers the result is shown in the Attachment.
The forum file size limitation restricted the attachment size.
