Old 25-06-2018, 19:13   #76
Jun 25th, 2018 partial log ...
Frequency: +
Codec: -
Modulation: -
Old 27-06-2018, 17:52   #77
Jun 27th, 2018 partial log ...
Frequency: +
Codec: -
Modulation: -
Old 05-07-2018, 19:53   #78
Jul 5th, 2018 log ...
Frequency: +
Codec: -
Modulation: -
Old 07-07-2018, 11:49   #79
Jul 6th, 2018 log ...
Frequency: +
Codec: -
Modulation: -
Old 07-07-2018, 12:31   #80
No signal in France
Old 09-07-2018, 11:47   #81
It is Monday 9 July at 1115 UTC (8:45 am local time). Yesterday afternoon, our local electricity unaccountably died for an hour. That reset my MorphyRichards 27024's clock back to its defaults, some time and date in 2006. Long ago, I gave up trying to put in the correct time myself, hoping for a DRM station to reset it for me. Manually, that takes about fifteen minutes of constant turning a button; but it's just a few seconds of the right DRM. Sadly, most of the regular DRM stations don't have that particular aspect of their DRM settings in place. For instance, neither Kuwait nor Romania resets my clock.
I do listen to DRM on both Kuwait and RRI. WINB's DRM I cannot listen to for its oddball fire&brimstone stuff. But WINB's peculiar programming is made up for by its clock correction!
Their signal is not strong enough here today to hear more than a few seconds of audio every minute or so. But within a few seconds of my tuning in, it had brought my MR27024 around to the proper time & date. The MER rates are vaying this morning from about 11 dB (too low for audio) to 18 dB (good for audio).
Downtown St. John's, Newfoundland.
Old 12-07-2018, 01:26   #82
Jul 11th, 2018 partial log ...
Frequency: +
Codec: -
Modulation: -
Old 12-07-2018, 18:08   #83
Jul 12th, 2018 partial log ...
Frequency: +
Codec: -
Modulation: -
From this date, I will NO longer listen to any non-xHE-AAC audio even IF the digital signal can be decoded. Thankfully, current bugs in my GR-216 and the inappropriate use of 64 QAM modulation make it easy to do. It's time to move to xHE-AAC and 16 QAM modulation on shortwave.
Old 16-07-2018, 18:26   #84
Jul 16th, 2018 partial log ...
Frequency: +
Codec: -
Modulation: -
The relative emitted energy between the upper and lower 5 kHz segments has apparently changed with better synchronization at my receiver as a result. Regardless, I won't be listening to AAC+ broadcasts anyway.
Old 17-07-2018, 17:53   #85
Jul 17th, 2018 partial log ...
Frequency: +
Codec: -
Modulation: -
Old 19-07-2018, 15:40   #86
Jul 18th, 2018 partial log ...
Frequency: +
Codec: -
Modulation: -
Old 24-07-2018, 14:16   #87
WINB 15670 kHz Latest Spectral View
Nice reception this morning by the KiwiSDR web receiver near Tampa, Florida, USA.
The attachment shows the latest spectral view of the signal. The DRM portion of the signal is the right half, and the left half is the datacasting stream.
The datacast looks like an USB signal modulated with multi tones.
The small size of the attachment is due to this Forum's file size limitation.
Old 24-07-2018, 17:42   #88
WINB with carrier on Datacast portion
While continuing to monitor WINB via a UK KiwiSDR web receiver, at around 1700 UTC, I noticed a definite carrier on the datacast portion of the signal. I then switched to the Tampa, Florida receiver and the spectrum was the same. It did not appear to be external interference.
Very shortly after saving the screen shot the WINB signal disappeared.
The spectrum with the carrier in the datacast is shown in the attachment.
Earlier the data part of the signal appeared to be USB, is it normally DSB with suppressed carrier?
Old 03-08-2018, 08:25   #89
WINB DRM Off
DRM transmitter is off, needs a part before they can come back on.
Old 10-08-2018, 16:39   #90
WINB 15670 kHz Reception in Southwest England
This morning WINB resumed datacasting (together with its poor DRM sibling transmission).
Checking the various KiwiSDR web receivers in Europe there were very few that were receiving a signal good enough for decoding the DRM.
Here is the log from a receiver with a good antenna in England (the receiver auto times out after about 30 minutes).
The propagation conditions, today, were excellent with the planetary K-index at zero! Even so the WINB DRM audio decoding was less than a third of the logging period.
