Old 15-07-2017, 20:43   #31
Hello DRM Hdn,
Is curious to your Dream no audio, my Dream is good audio :
http://nsa38.casimages.com/img/2017/...0503585259.jpg
Old 15-07-2017, 20:55   #32
DRM Hdn
DRM Hdn's Avatar
Hello Marcel, yes it is curious and strange. Don't know why it not works with my configuration.
F1BJB has the same problem if i read his post correctly.
Old 15-07-2017, 21:08   #33
There was no DRM at 1800, so I left DReaM (1.6.1csv) on and noticed that something was playing around 1814 UTC and at that time I started the log. Looking in History it seems like the transmission had started around 1804 UTC. Max. 27.97 dB SNR and only 51% decoded audio. A mostly unattended log. The audio quality was very good when I listened.
Old 15-07-2017, 22:20   #34
July_15
A partially unattended log. The DRM transmission started around 18:04, before that was AM. I do not know what happened after about 20:20, may be the propagation conditions changed and the signal dropped. Max SNR noticed 35.5dB.
Old 15-07-2017, 22:26   #35
Hi John, exactly the same noted here, the signal started to drop and I could see on the waterfall that there was a lot of selective fading on the signal, it started to drop out a lot after 20:20.
Apart from the slightly late start it had been very good up until then. This may have been to blame:
Strong solar flare and CME
After days of suspenseful quiet, huge sunspot AR2665 finally erupted on July 14th (0209 UT), producing a powerful M2-class solar flare.
The explosion was underway for more than two hours and hurled a bright coronal mass ejection (CME) toward Earth.
Geomagnetic storms and high-latitude auroras are likely when the CME arrives this weekend.
Visit Spaceweather.com for images and updates.
Modified NRD-525G with
Radiokit DRM Decoder Board,
SDRplay RSP-1A, SDR Console v3
Lancashire, UK
53:39.18N 02:10.28W
IO83vp
https://www.ndblist.info
Old 16-07-2017, 04:17   #36
Just a few seconds of decoding here in New Zealand today.
Old 16-07-2017, 16:02   #37
Excellent DRM service from Radio Kuwait 15540 kHz, between 18 & 21 UTC (15 Jul 2017). Listening in Brazil: https://youtu.be/OZq8gzwyQSM
Please share videos and Keep this Digital broadcast (if anyone on the radio reads). You can always count on the tuning here from Brazil, at least on weekends!
Old 16-07-2017, 18:25   #38
15 Jul 2017 : Radio Kuwait on 15540 kHz from Al Kabd
There was 99+% decoded audio until the last 30 minutes of the transmission.
15:00-18:00 UTC Planetary K-index 0+. Local K-index 1.
18:00-21:00 UTC Planetary K-index 1-. Local K-index 1.
Planetary A-index: 4. Solar flux: 88. SESC Sunspot number: 58.
Sunset 20:14 UTC.
Old 16-07-2017, 19:50   #39
The signal is too weak here in Stockholm at 1850 UTC. Too high Kp and too much Aurora. No log.
Old 16-07-2017, 22:10   #40
July_16
A 152 mins log. Max SNR 36.6dB.
Old 17-07-2017, 00:17   #41
Radio Kuwait DRM, listening in Brazil
Strong signal. The broadcasting starts at 13h and finished at 21 UTC. Congratulations to Spectrum Manager from Radio Kuwait. There is any e-mail or site's radio?
Vídeo: https://youtu.be/Or89Y-BjV2o
Old 17-07-2017, 08:54   #42
Regarding the TX site, is Sulaibiyah correct? Somewhere I read Kabd. And in Kabd there is a Sulaibiyah road passing by. I found one TX site at 29.513853 N / 47.674414 E in the sandbox. If anyone has a better location than Sulaibiyah then let me know. But the difference in kilometres may not be too different in any case...
Old 17-07-2017, 12:17   #43
July_17
@ Terje
I found out in my archives this old info:
13620 kHz
47
53
29
16
Sulaibiyah (KWT)
Old 17-07-2017, 12:58   #44
oh2bfo
Ampegon press release calls it Al Kabd:
http://ampegon.com/news/?id=80
13620 kHz
47
53
29
16
Sulaibiyah (KWT)
The same coordinates can also be found here:
http://www.itu.int/en/ITU-R/terrestr...ables/site.txt
Code:
KBD KABD KWT 29N16 047E53
But it's probably not the correct location. This place looks better:
https://www.google.com/maps/@?api=1&...emap=satellite
(The coordinates Terje found point to IBB's Kuwait TX station.)
oh2bfo is offline   Reply With Quote
Old 17-07-2017, 14:42   #45
16 Jul 2017 : Radio Kuwait on 15540 kHz from Al Kabd
There was only 64% decoded audio during the transmission.
15:00-18:00 UTC Planetary K-index 6-. Local K-index 5.
18:00-21:00 UTC Planetary K-index 6. Local K-index 5.
Planetary A-index: 4. Solar flux: 88. SESC Sunspot number: 34.
Sunset 21:13 UTC.
