Old 12-07-2017, 18:33   #1
Radioeng
15540kHz -Unidentified
Just tuned in to listen to Radio Kuwait in English in AM and found a DRM signal. The label just says DRM Service A, with a good signal level (average 22dB MER as measured by a Morphy Richards 27024) , 17.46 kbps, 4/64 QAM but no audio is decoding.
Radio Kuwait testing DRM? They were a major user years back.
Kevin R (Reading, UK)
Apologies for mis-typed frequency on original post.
Radioeng is offline   Reply With Quote
Old 12-07-2017, 19:19   #2
At what time?
Old 12-07-2017, 20:22   #3
Radioeng
15540 KHz - 1800-2100 UTC?
I heard it at 18.30 UTC, still operating at 20.25 UTC.
Kevin R
Old 13-07-2017, 18:11   #4
There is something going on on 15540 kHz just now at 1808 UTC, 0 kbps (=no audio present), B/10 kHz, 4/64, P0/0. SNR hovers around 23-24 dB. SDC is yellow in DReaM V1.6.1.
Grrr... I monitored 15450 kHz all day up until now...
Old 13-07-2017, 18:20   #5
I am at work where I have only my little Grundig YB400PE. I can hear a solid DRM-like hiss on 15540 at 1815 - 1820 UTC Thursday 13/7/17. Twente's SDR shows it quite clearly, by the way.
Philip
Old 13-07-2017, 18:46   #6
It is visible on kiwisdr.ve6slp.ca too at 1843 UTC.
The signal in Stockholm is about 28-32 dBuv.
The QRG is normally allocated to Kuwait between 18-21 UTC.
Old 13-07-2017, 18:47   #7
July_13
I received this transmission. After several attempts to run the TX finally made it. The signal was strong 60 - 70 dBuV, the label box was empty, no audio but 36.8 dB max SNR...(In the 1st plot the mode parameters are displayed).
Old 13-07-2017, 18:52   #8
I am DRM signal at 18H36 of 15540 Khz no audio signal, first picture with SODIRA and other with DREAM 1.13 :
http://nsa38.casimages.com/img/2017/...1335502696.jpg
http://nsa38.casimages.com/img/2017/...1705632832.jpg
Old 13-07-2017, 19:04   #9
18H58 other screen copy SNR strong :
http://nsa37.casimages.com/img/2017/...2831692960.jpg
Old 13-07-2017, 19:12   #10
July_13
The DRM_Software_Radio displays something peculiar, take a look at the screenshot.
EDIT: SoDIRA displays that the Audio Codec is: CELT.
File Type: png DRM_Software_Radio_15540_mode_mitajohn.png (8.1 KB, 258 views)
Old 13-07-2017, 19:19   #11
Buy a Gospell GR-216 and listen to the English transmission from Kuwait! The RF signal has decreased a lot over the last 30 minutes here so I'll listen in again tomorrow.
Old 13-07-2017, 19:53   #12
16.8db SNR here, but still only 4 green lights and no ID as yet. They've recently returned to Shortwave after having a new TX installed (by Ampegon I think), and have been putting a good AM signal in on 15540 since they came back on again. I'll try it a bit earlier tomorrow, the Bulgarian DX Blog shows it as 1800 to 2100 UTC.
Old 13-07-2017, 20:07   #13
My log with Dream. The signal died due to poor propagation later in the evening.
Old 14-07-2017, 18:11   #14
Tonight you can log Kuwait with DReaM. Log later.
@ Alan: I think they used the xHE-AAC mode last night.
Old 14-07-2017, 18:16   #15
Coming in well at the moment and giving very good audio. The signal strength isn't much different to what it was last night, so it looks like they might have changed something.
