Old 20-04-2015, 17:48   #1
AIR on 7550 kHz from Bangalore
AIR Test transmissions from 20 April to 30 April 2015. A strong signal, but CIR is bad. Chopped audio. And - they have forgotten to switch on the hum tonight!
21 dB SNR and chopped up audio...
A 286 minutes long, partly unnatended with 54.6% decoded audio. Max SNR was 28.48 dB at 2045 UTC.
The second attachment is a 45 minutes segment from 2026 UTC. Despite an average SNR of 25 dB the decoded audio was only 96%. There must be a better configuration?! I believe that the bad CIR is the biggest problem to the decoding.
Old 20-04-2015, 20:31   #2
April_20
Strong signal about 60dBuV, SNR reached 20 dBs, bad IR, no audio.
Old 21-04-2015, 21:10   #3
A little more decoded audio (74.66%) tonight in this 193 minutes long log. I must admit that this is the first transmission I've heard from India without hum on the audio.
Old 22-04-2015, 20:44   #4
64% decoded audio in tonight's log. I stopped the log after 164 minutes of hick-hack audio.
Old 23-04-2015, 18:27   #5
Strong signal but only short pieces of the 2 audio channels decoded
Old 23-04-2015, 20:50   #6
57.6% decoded audio during the 177 minutes long log. If the one hour drop-out wouldn't have been, then the decoded audio would have hit about 87%. The mode used does not deliver any uninterrupted audio even with 25 dB SNR! The only thing woth mentioning for this test is that it is probably the first time I have heard AIR with audio without hum and hiss in the modulation.
Old 24-04-2015, 20:40   #7
Report from 24.04.2015:
The transmission started early. I noticed TEST MUSIC with music at 1720 UTC and the REGULAR SERVICE was silent at that point. Soon after at 1723 UTC the RF signal disappeared. Around 1730 UTC the signal came back on the air.
A strong signal with 55 dBuV into my receiver, but the Channel Impulse Ratio
is again very bad. Chopped up audio all the time. And after 1856 UTC there
was no decoded audio at all despite this strong RF signal. Now at 2012 UTC
the SNR hovers around 18 dB, but like I wrote above, there is ZERO decoded
audio.
A 182 minutes long, partly unattended with 25.25% decoded audio. Max SNR was 24.21 dB at 1732 UTC.
Despite an average SNR of 22 dB the decoded audio was only 50.6% between
1730-1856 UTC. There must be a better configuration?! I still believe that
the bad CIR is the biggest problem to the decoding here in Scandinavia.
Old 25-04-2015, 20:40   #8
The transmission started early today too. I noticed TEST MUSIC with silence at 1718 UTC and the REGULAR SERVICE was silent too at that point. Soon after at 1721 UTC the RF signal disappeared. Around 1740 UTC the DRM signal came back on the air.
A strong signal with 60-67 dBuV into my receiver, but the audio was chopped up all the time if there was any audio at all. After 1755 UTC there
was virually no decoded audio at all despite the strong RF signal.
A 122 minutes long, partly unattended with 3.15% decoded audio. Max SNR was 22.28 dB at 1751 UTC.
Old 27-04-2015, 05:41   #9
26 apr 2015
The transmission started with AM today. I was surprised to hear this, but I left the radio on the frequency and at 1747 UTC it switched to DRM. A strong signal with >60 dBuV into my receiver's antenna, but the audio was slightly chopped up all the time despite the relatively high mean SNR of 24.5 dB for the whole transmission. Is the protection level 3/0 the best they can do with this configuration?
A 282 minutes long, mostly unattended with 91.5% decoded audio. Max SNR was 29.5 dB at 2117 UTC. The Doppler was lower tonight with an average of 0.32 Hz. This, plus the slightly better Channel Impulse Ratio might have helped to produce more decoded audio.
A programme announcer mentioned "Non-Stop Express" at 2030 UTC on the TEST MUSIC channel followed by light Indian music. The Regular Service started in English, but later on I heard native language(s) and typical Indian music like the transmissions on 9.950 MHz.
Old 27-04-2015, 08:40   #10
peter-s-drm
peter-s-drm's Avatar
The problem with the high needs of SNR to decode is Protection Level 3. AIR should test with Protection Level 1 or 2 and possible only one audio stream.
peter-s-drm is offline   Reply With Quote
Old 27-04-2015, 21:12   #11
Hi Peter and all,
I suggested the Spectrum Manager at AIR to set a more robust protection level (if possible with what they are doing) but got only an answer with a request for my full address (given to them a couple of times) to send me a QSL card. A QSL card is very welcome, but I think, especially as they call it a test transmission, they should then experiment a little with the settings.
But the propagation was much better last night compared to now. Only 17.5% decoded audio and the SNR was 18.7 dB on average. It would have been about 4-6 dB better if I had remembered to set the AGC to "slow". The Channel Impulse Response was pretty awful this evening adding to the bad result.
Old 28-04-2015, 18:20   #12
April_28
The signal is strong >60dBuV and stable but the CIR is terrible, no decoding possible.
Old 28-04-2015, 19:00   #13
AIR tests on 7550 kHz, 28 apr. 2015
...and Mode C doesn't do any good either! But the CIR is completely hopeless. Propagation is a mess in 7 MHz this evening...
It started out pretty bad, but after 1930 UTC the propagation conditions improved and from 2050 UTC the reception was perfect until the end in my log at 2229 UTC.
I logged the transmission with two receivers. The log taken with the Newstar DR111 looks much the same.
Old 30-04-2015, 09:53   #14
Last night (29th April) the DRM transmission started late. Before 1947 UTC
there was AM on 7550 kHz. Suddenly the DRM signal appeared. Maximum SNR
reached 27.59 dB and the average SNR for the log was 23.48 dB. The average
Doppler was 0.55 Hz. Despite the high SNR the audio was very chopped up,
probably because of the lack of robustness. The result was less than 75%
decoded audio.
Enclosed is my log from last night until my DRM Log-Plotter switched the
system down at 2230 UTC.
Old 30-04-2015, 18:28   #15
30th April ended with a flop
So far (until 1822 UTC) it seems to me that they have either forgotten to plug in the audio source(s) or the propagation is down the drain. SDC is red and MSC is gray. The RF signal received here is around S9+20 dB which in my case means an input level of +58 dBuV which is more than 0.5 mV into the antenna socket.
The SNR was around 5 dB until 2115 UTC when, after a few breaks in the DRM transmission, the SNR suddenly rose to more than 20 dB and the labels appeared. The bitrate was 11.72 kbps on both channels. Propagation wasn't good and the CIR was flat. At 2125 UTC I noted the comment "Non-stop Express", which seems to be a music programme with light native popular music.
They used Mode A for this transmission, but the P3/0 was not robust enough. What they were up to from 1752 until 2115 I have no idea. Probably they had managed to have chosen a bad DRM configuration.
If this was the last transmission in the test, it was a disappointment. We just have to wait for the next test.
