Old 05-12-2014, 21:05   #16
5 Dec 2014 : NHK World via Babcock from Woofferton 9760 kHz
99% decoded audio, nearly perfect signal.
09:00-12:00 UTC Planetary K-index 2. Local K-index 2.
Planetary A-index: 11. Solar flux: 158. SWPC Sunspot number: 137.
Old 06-12-2014, 11:43   #17
Dec 6
Well, my first try with DRM for a couple of months, was not too good.
At first I had to find the DRM schedule, so that I could update the DRMDISC and start looking for the first signal.
Finally at 11:00 UTC I started 'listening' to this station identifying with the strange name "Babcock".
In total just 8% CDA, so I'll guess I stick to my Sonos Play:1.
Old 06-12-2014, 13:58   #18
An unattended auto-log with no label. About 75% decoded audio.
Old 07-12-2014, 06:55   #19
Who is Babcock?
Hi Per,
Babcock, or more correctly Babcock International PLC, merged with VT Group PLC in March 2010. VT Communications was a part of VT Group. VT Communications was the company formed from the privatisation of the BBC World Service transmitter sites. It was initially named Merlin Communications, then, after acquisition by VT, VT Merlin Communications
'VT' was an abbreviation of Vosper Thorneycroft, and PLC is an abbreviation of Public Limited Company.
Old 07-12-2014, 07:09   #20
6 Dec 2014 : KBS World via Babcock from Woofferton 9760 kHz
Perfect, 100% decoded audio!
Planetary A-index: 11. Solar flux: 137. SWPC Sunspot number: 97.
Old 13-12-2014, 07:07   #21
12 Dec 2014 : NHK World via Babcock from Woofferton 9760 kHz
97% decoded audio.
09:00-12:00 UTC Planetary K-index 3-. Local K-index 2.
Planetary A-index: xx. Solar flux: xxx. SWPC Sunspot number: xxx.
Old 13-12-2014, 11:42   #22
KBS via WOF
The first 6 and the last 15 minutes were perfect. Now that is an interesting DRM configuration: 4/16 QAM, Mode A, 18.44 kbps and AAC+. Sounds very good! Look here AIR! See what you can do!
Old 13-12-2014, 14:20   #23
13 Dec 2014 : KBS World via Babcock from Woofferton 9760 kHz
70% decoded audio, which is not as good as usual.
09:00-12:00 UTC Planetary K-index 1. Local K-index 1.
Old 16-12-2014, 12:58   #24
Someone pushed the wrong button? BBC WorldService on 9760 kHz, but it was short!
Old 19-12-2014, 13:47   #25
19 Dec 2014 : NHK World via Babcock from Woofferton 9760 kHz
73% decoded audio.
Planetary A-index: 5. Solar flux: 213. SWPC Sunspot number: 165.
Old 20-12-2014, 11:35   #26
Dec_20
No good results, during the last 10 mins it turned a bit better.
Old 20-12-2014, 12:44   #27
Not very good here either. Less than 60% decoded audio made listening problematic.
Old 20-12-2014, 23:04   #28
20 Dec 2014 : KBS World via Babcock from Woofferton 9760 kHz
51% decoded audio, which is not as good as usual.
09:00-12:00 UTC Planetary K-index 1+. Local K-index 1.
Planetary A-index: 8. Solar flux: 216. SWPC Sunspot number: 156.
Old 26-12-2014, 13:19   #29
26 Dec 2014 : NHK World via Babcock from Woofferton 9760 kHz
85% decoded audio.
09:00-12:00 UTC Planetary K-index 2-. Local K-index 1.
Planetary A-index: 12. Solar flux: 145. SWPC Sunspot number: 100.
Old 28-12-2014, 06:59   #30
27 Dec 2014 : KBS World via Babcock from Woofferton 9760 kHz
50% decoded audio, all in the second half of the transmission.
09:00-12:00 UTC Planetary K-index 2-. Local K-index 2.
Planetary A-index: 17. Solar flux: 137. SWPC Sunspot number: 92.
