Old 20-01-2014, 10:15   #1
17895 kHz AIR Test 1
All India Radio noted here in Wellington, New Zealand, on 17895 kHz, with "AIR Test 1" label from 1000-1100 UTC. No audio decoded.
According to Jose Jacob in the dx_india Yahoo Group this is Bengaluru:
New DRM transmissions is monitored from AIR Bengaluru today (19 Jan 2014) as follows:
1000-1100 UTC 17895 English to Australia & NZ
1145-1315 UTC 15795 Chinese
Look out for more DRM broadcasts from this station at other timings in External Services of AIR.
Old 20-01-2014, 11:41   #2
There is a weak signal of about 15 dBuV here now at 1230 UTC. So far the MSC has been constantly red. A peculiar configuration with 8.08 kbps aac and Protection 3/0. And that with 16/64 !
A half hour of nothing:
Old 21-01-2014, 10:04   #3
My log showed 3 little green blips within the first 30 minutes.
With all of these digital tests and plans for this year, 2014 is looking increasingly like the year of DRM.
Old 23-01-2014, 00:21   #4
Looking back at my logs, 2003 was the year of DRM ;-)
http://www.owdjim.gen.nz/chris/radio/DRM/2003.php
It is good to actually have a broadcaster sending DRM to Aus/NZ in 2014 though. Now, if they can just get their transmission parameters sorted out I might be able to listen.....
Old 23-01-2014, 01:20   #5
OT -
The broadcasters were there, but the mature technology (xHE-AAC) and listeners weren't evidently. Personally, I'd like to see a comparative survey of people knowing about DRM around 2004 and those people knowing about DRM today (2014). Honestly, I don't expect much difference so the DRM Consortium has likely failed in the aspect of publicity. Although some major broadcasters have reduced their presence on shortwave and closed facilities, 2014 is looking to be different in a number of ways, the xHE-AAC codec and disillusionment with the InterNet (spying, etc). Personally, I can't wait to stop paying for access to buffering servers which then ban the IP address of my proxy servers. I'm too cheap anyway. We'll see as 2014 progresses.
I should have been clearer, though.
I agree totally with need for more intelligent transmission parameters.
Your logs are very interesting as they generally tell a story of poor configuration and too little power. It's amazing to look at the number of incomplete broadcasts due to inadequate selection of frequencies for the season of the targeted area and adjacent frequencies, inappropriate bit-rates for type of content, and common usage of 64 QAM for the MSC. RNW had the right idea, but even their configuration suffered unnecessarily. RNW's broadcast from Bonaire improved toward October (southern spring) on 15400 kHz... I loved the comment about Marconi on the Nov. 16, 2003 broadcast from RNW on 15255 kHz ... Great stuff, Chris!
Old 23-01-2014, 14:31   #6
AIR Bangalore, India, 15795 kHz reception near Atlanta, Georgia, USA
Wrong frequency thread, moving this to new AIR Test 15795 kHz thread.
This morning's reception - no audio decoded, 4.87 dB max SNR.
I was not present to grab the screen ID.
Old 16-02-2014, 19:14   #7
This transmission, aimed supposedly at Australia & New Zealand, continues to remain reliably undecodable here in New Zealand
I wish the folks at Bangalore would try using the same DRM parameters as Khampur.
Old 19-02-2014, 11:53   #8
In Japan I can see traces of a DRM signal, but that is all. Time: 1245 UTC.
Old 19-02-2014, 22:56   #9
No traces at all of DRM on the 19th January here in Japan.
Old 20-02-2014, 23:22   #10
20th Feb
AIR supposed to be testing but no DRM seen around 1215 UTC but lots of co-channel AM QRM.
Old 02-03-2014, 12:01   #11
Same hopeless configuration on this frequency. Bitrate is 8 kbps and the Protection level is 3/0. Mode A.
Certainly a test for nobody to receive. It is not even worth wasting hard disk space for this kind of rubbish!
PS: 10 seconds of audio at 1252 UTC when the SNR suddenly rose to 18 dB, but that was it.
Old 03-04-2014, 11:41   #12
Weak signal ,no ident except mode A
Old 14-04-2014, 14:29   #13
Medium reception from AIR TEST 1 audio cut SNR : 17 to 20,8 db :
http://nsa34.casimages.com/img/2014/...4203200447.jpg
Old 29-04-2014, 17:55   #14
17895 kHz
Some signal seen here on the 28th. 46 minutes of nothing.
Old 30-04-2014, 13:50   #15
Wow, they manged to flip another button: Today it was Mode B, but still 8 kbps, P3/0 and 16/64. Which means - no improvement.
The Label now says "SPT Bangalore".
