Schneider DRM Universal Miniature Mixer and Degen 1103
  • Filter
  • Time
  • Show
  • tpreitzel
    • Apr 2012
    • 2985
    Ok,
    My mixer unit arrived today. I originally planned to tap the IF output through coax leading out of the Degen 1103 into this mixer and run it via a 9 v battery. Since the mixer is so small, I'm wondering if it can be installed internally in Degen's 1103. Does the 1103 have sufficient voltage, i.e. 7 to 20 v, to operate this mixer without the need of a 9v battery? I doubt it since the 1103 runs on 4x1.5v batteries or AC. If so, where do I tap this voltage? TIA
    P.S. I'm in no rush as I'm waiting on my copper shielding to arrive as I plan to modify Degen's 1103 all at once. I really want this installation to be as neat as possible.
  • tpreitzel
    • Apr 2012
    • 2985
    #2
    My copper sheeting arrived so my modifications of shielding and adding Schneider's DRM board to Degen's 1103 are complete. The Degen 1103 is now considerably less susceptible to interference. Now, I receive the station ID with the DRM board installed. I've been experimenting with adjusting the two tunable controls. I think both the waveform and levels are close to correct. However, I'm still not receiving the MSC CRC so no audio.
    • dadalbinder
      • Feb 2006
      • 369
      #3
      just try the converter first on AM-mode or SSB and You will have a result for normal working.
      The question is further, wether Your antenna is sensible or reliable for Your receiving place.
      Greetings
      Wolfgang Hartmann, Nürnberg
      • tpreitzel
        • Apr 2012
        • 2985
        #4
        Originally posted by dadalbinder
        Greetings
        Problem solved. I just heard my FIRST DRM broadcast and I'm, I'm nearly speechless. Wow! The broadcast was REE (Cariari in Costa Rica) and the SNR was averaging ~ 20db. The occasional dropouts can be a bit obnoxious, but other than that minor nuisance, I'm stunned at the quality considering the medium, shortwave. Kudos to the manufacturer of this DRM board and the engineering team responsible for the DRM standard. We need to replace iBiquity with DRM for MW broadcasts in the USA as well. BTW, thanks Wolfgang ... Amazing...
        • mvs sarma
          • Apr 2007
          • 220
          #5
          CONGRATS, tpreitzel
          Many had a perception that DE1103 is unfit for drm converter.
          Only 2 members to my knowledge worked on this. In addition to you Siber did try and succeed. he had sent few sch also to me.
          I would suggest to tahe few photos of how and where you mounted the converter unit inside the radio, and how did you bring out the 12KHz IF out. as time and facilities permit , even a small youtube video would be nice. Happy that you get drm signals decoded on DE1103.
          It is encouraging....
          Sarma
          • tpreitzel
            • Apr 2012
            • 2985
            #6
            Originally posted by mvs sarma
            CONGRATS, tpreitzel
            Don't get too excited.
            I took the easy route. I simply ran a piece of shielded cable through an enlarged hole (round file) reserved for the carrying strap into Schneider's board which I'm powering with a rechargeable 9v Ni-MH battery. While the Degen 1103 was apart, I added shielding via instructions found on the InterNet, but I, unfortunately, did NOT modify the 1103 for increasing its sensitivity at higher frequencies. Therefore, I can't decode the audio from DRM broadcasts above ~ 14 MHz, e.g. Disco Palace from French Guiana. In retrospect, I should have modified the 1103 to increase its sensitivity at higher frequencies while I was adding the shielding. I still could, but it's smarter to just buy another portable dedicated to receiving DRM broadcasts, e.g. Newstar's DR111, and forgo the modifications and use of DReaM. With the exception of my failure to modify the 1103 for use at higher frequencies, I'm quite pleased with the Degen 1103 and Schneider's board. It does work and work well. However, if I hadn't already owned a Degen 1103 and I were just entering the market for a portable DRM receiver, I'd simply buy Newstar's DR111 today.
            • mvs sarma
              • Apr 2007
              • 220
              #7
              i am satisfied the way you did.
              It is no excitatin, at my age of 67 and experience of 40 years in telecom hardware servicing. it is a question of making the de1103 worok for drm decoding. it has 450KHz if compared to 455 in many other Receivers. As of now as many receiver manufacturers are not reday across the market, the drm receivers like drm111, hymalaya 200x etc would be rather costly.
              I better wait for Indian scenario as they are to commission many DRM Transmitters this year. Perhaps Receivers would also pour in including few local made.
              As i am into electronics hobby, I have been managing with pc/laptop based dream decoding and happy with it.
              thanks for your fast reply. BTW, if the Rx you bought is lartest MKIII or IV, then all the old mods mentioned across may not be needed. A good ant with due lightening etc protection would help Rx on higher bands. I use an active mini patch antenna of PA0RDT design using J310 and 2N5109. it has been working fine for me.
              Sarma
              • tpreitzel
                • Apr 2012
                • 2985
                #8
                Yes, I expect DRM to rapidly increase in popularity at some point in the future as the standard is just too good to ignore.
                My Degen 1103 is from the original production in early 2004 so it required significant modification. I just didn't modify it enough unfortunately. Currently, my antenna is a 30' long wire with an 1/8" mini jack fed outside through a small hole in a window screen since my residence has METAL siding. This combination works pretty well. I just bought a MFJ 1020C which I'm planning to use as a tuned pre-selector for the long wire, but it's likely overkill. I can always use the MFJ 1020C with other receivers as well. Thanks for the suggestions. DRM has a bright future.
                • Siber
                  • Oct 2008
                  • 86
                  #9
                  Hi all!
                  If anybody needs it.
                  I have made the latest version of Degen 1103 converter 450/12 kHz.
                  It has the own IF 450 filter with 20 kHz passband and uses the Degen's power source .
                  The converter module placed inside of the receiver.
