Old 21-06-2015, 07:06   #811
20 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC and had 100% decoded audio.
18:00-21:00 UTC Planetary K-index 0. Local K-index 0.
Planetary A-index: 5. Solar flux: 134. SWPC Sunspot number: 74.
Sunset 20:24 UTC.
Old 21-06-2015, 19:47   #812
Mikey
Almost perfect except the few occasions when they decided to turn off the transmitter
Old 21-06-2015, 19:53   #813
June_21
An unattended 52 mins log. It seems that one TX break down took place for several minutes.
Old 22-06-2015, 05:57   #814
21 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC. There were what looks like two breaks in transmission, one very short near the beginning and a longer one towards the end. When on air there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 2+. Local K-index 2.
Planetary A-index: 2. Solar flux: 133. SWPC Sunspot number: 89.
Sunset 21:24 UTC.
Old 22-06-2015, 20:44   #815
22 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC, with two breaks. When on air there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 8+. Local K-index 8.
Planetary A-index: 8. Solar flux: 130. SWPC Sunspot number: 79.
Solar radiation storms reaching the S2 level.
Radio blackouts reaching the R1 level.
Sunset 20:24 UTC.
Old 24-06-2015, 06:12   #816
23 Jun 2015 : Voice of Nigeria 15120 kHz
No signal was received tonight, so I assume it was off the air.
Old 25-06-2015, 06:06   #817
24 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC with one break of transmission of approximately 5 minutes. When on air there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 2+. Local K-index 3.
Planetary A-index: 76. Solar flux: 115. SWPC Sunspot number: 61.
Sunset 20:24 UTC.
Old 25-06-2015, 09:49   #818
Perfect reception here at my place except for one 5-minute TX break as Neil mentioned.
Old 25-06-2015, 20:23   #819
Perfect reception here at my place except for one 15-minute TX break
Old 26-06-2015, 06:20   #820
25 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC with a 15 minute break in transmission. When on air there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 3. Local K-index 3.
Planetary A-index: 17. Solar flux: 103. SWPC Sunspot number: 39.
Sunset 20:24 UTC.
Old 27-06-2015, 13:41   #821
26 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:50 UTC, which is an extra 20 minutes which was in an African language! There were 3 short breaks, when on air there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 1. Local K-index 1.
Planetary A-index: 33. Solar flux: 101. SWPC Sunspot number: 33.
Sunset 21:24 UTC.
Old 28-06-2015, 06:34   #822
27 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC, with 3 breaks in transmission. When on air there was 99+% decoded audio.
18:00-21:00 UTC Planetary K-index 1+. Local K-index 1.
Planetary A-index: 10. Solar flux: 98. SWPC Sunspot number: 28.
Sunset 20:24 UTC.
Old 29-06-2015, 22:16   #823
28 Jun 2015 : Voice of Nigeria 15120 kHz
Old 29-06-2015, 22:30   #824
29 Jun 2015 : Voice of Nigeria 15120 kHz
The transmission was on air from 18:00-19:30 UTC. There was at least 2 short breaks in the transmission. When on air there was 100% decoded audio.
18:00-21:00 UTC Planetary K-index 1-. Local K-index 1.
Planetary A-index: 13. Solar flux: 97. SWPC Sunspot number: 25.
Sunset 20:24 UTC.
There is no plot as the Newstar froze part way through the transmission, but I was able to listen via the Morphy Richards.
Old 30-06-2015, 19:48   #825
Mikey
98.66% decoded. Average SNR 13db. decode rate would have been better if the TX had not kept cutting out.
