Old 30-10-2011, 17:16   #1
12115 kHz The Disco Palace from ISS to India
Some audio decoding possible today.
Old 30-10-2011, 19:32   #2
This freq was not good her in Sweden . Pleas QSY back to 15775 !!!!! Log 11min.
Old 31-10-2011, 09:06   #3
I can only agree to the previous post.
Regards
http://www.omnirep.se/drm/
Old 31-10-2011, 15:45   #4
Not much better today either.
Regards
Old 31-10-2011, 18:16   #5
Not too bad for my location.
Old 04-11-2011, 16:28   #6
Excellent results today.
Old 06-11-2011, 16:09   #7
Quite good results except for the last 12 minutes.
Old 08-11-2011, 15:40   #8
First time for audio on this freq. Log 25min. MAX SNR 30.05db!!
Old 13-11-2011, 18:41   #9
Juan_CAT
Juan_CAT's Avatar
Yesterday, 12th November.
From 15:30 GMT to 15:34
Max SNR: 20,9 dB Audio decoded: 74%
From 15:34 to 15:39
Max SNR: 19,5 dB Audio decoded: 61%
From 15:39 to 15:48
Max SNR: 20,6 dB Audio decoded: 79%
Since 15:50, no audio decodification was possible with telescopic antenna because SNR was too low (<17 dB). Touching the antenna, I was able to continue to listen this station almost without interruptions during 15 minutes or a little more, then signal went worse.
Juan_CAT is offline   Reply With Quote
Old 17-11-2011, 15:35   #10
Not bad today:
http://www.mar1386.com
Old 20-11-2011, 08:16   #11
Good results in the first 20 minutes yesterday, then signal got too weak.
Old 29-11-2011, 15:08   #12
Some kind of religious AM station started on the frequency at 1600 which was up to 30 dB stronger than ISS, but nothing listed in the HFCC list. Chinese on 12.120 MHz doesn't help either...
The AM station was happily chattering in an (for me, anyway) unrecognizable langue after 1630 as well..
Regards
Old 18-12-2011, 15:55   #13
Only a weak signal these days.
Old 18-12-2011, 16:15   #14
Very bad signal her also .
Old 16-01-2012, 20:54   #15
Conditions improved again, not too bad in the first half.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
