WAZ Nachricthen 9530/ 9655/ 17650 kHz
  • Filter
  • Time
  • Show
  • Alan Johnson
    • Apr 2003
    • 607
    If I am duplicating an existing thread, please forgive me.
    I saw a DRM waveform while I was getting ready to listen to TDP via Sackville and got this. The SNR was almost good enough for audio.
    I couldn't find it on the DRM schedule I have bookmarked. Can anyone give me any information on this broadcast? I can't believe I was getting reception from Germany on 31 meters 3 1/2 hours before my local sunset.
    Alan Johnson
    N4LUS
  • drmdab
    • Dec 2006
    • 700
    #2
    This was posted in DXLD some days ago:
    30 Jul 09 22:15 UT
    I don't see it on the official DRM list, EIBI nor ADDX, but I'm getting Echo des Tages DRM in German on 9530. S9+40. Near perfect decode, but low quality AAC+ Mono 14.56 kbps. Is this Sackville?
    Terry Wilson, MI
    Your "WAZ Nachrichten" broadcast is related to this newspaper: http://www.derwesten.de/
    • drmdab
      • Dec 2006
      • 700
      #3
      I can see this station right now, Journaline "WAZ Nachrichten". See http://www.dxaktuell.de/waz.png http://www.dxaktuell.de/wazjournaline.png
      Jülich?
      Edit: Station off at exactly 2305 UTC
      • Digger
        • Mar 2005
        • 10097
        #4
        An unattended log. Unfortunately, my automatic screen shot routine failed, so I did not get any labels or other data.
        • drmdab
          • Dec 2006
          • 700
          #5
          Now it's called "Echo des Tages" with 14 kbps audio.
          I bet it changes into Journaline again at 22.30 UTC...
          (Start time was short after 22.00)
          2205: Echo des Tages (audio)
          2235: WAZ Nachrichten (Journaline)
          2305: switch off
          Language: German, Country: Germany
          Exciting...
          • Digger
            • Mar 2005
            • 10097
            #6
            A short log. The signal was very weak, and "das Echo des Tages" could not be heard. The transmission started shortly after 22 UTC.
            • maxpower
              • Dec 2003
              • 479
              #7
              Very weak herewwith the 19m Deltaloop, too. No decoding possible.
              Does anybody know the source of this transmission today?
              Stephan
              • drmdab
                • Dec 2006
                • 700
                #8
                I got an audio-file of the Echo-transmission. The program content is from "NDR Info", which is the talk and news station of my regional broadcaster NDR, www.ndrinfo.de.
                Edit: This transmission originates from Nauen, Germany.
                Edit 2: Here's tonight's log of the Echo.
                • mitajohn
                  • Nov 2002
                  • 8439
                  #9
                  Aug. 05
                  I received this transmission tonight. The signal was fairly good but only fragments of decoded audio (German speaking voices). After 22:35 the audio stopped and replaced by Journaline which received perfectly. There were two different labels for the 1st and 2nd half of the transmission and two BRs too. Take a look at the attached images.
                  • Digger
                    • Mar 2005
                    • 10097
                    #10
                    5th Aug.
                    So it is Nauen. That is why the reception here is problematic; Nauen always was. I got surprisingly much decoded audio, more than expected. The "Echo des Tages" was just that: A summary of the news from NDR Info. Between 2219 and 2221 I noticed many interruptions in the DRM modulation. At 2221 UTC there was a time check "18:05". The Channel Impulse Response was high, about 4 to 6 ms, which seems to be bad for the decoding (?).
                    From approx. 2235 the label changed to WAZ Nachrichten, Journaline. I could retrieve all contents without problems.
                    • mitajohn
                      • Nov 2002
                      • 8439
                      #11
                      Aug. 06
                      No results tonight. Very weak signal + QRM. SNR 5 - 7 dB.
                      • f1tay
                        • Sep 2006
                        • 404
                        #12
                        Tentative of reception at Paris.
                        Daniel
                        • Alan Johnson
                          • Apr 2003
                          • 607
                          #13
                          8 Aug log
                          Excellent reception of both the audio and data segments today. I wonder what the transmission power and antenna beam heading are?
                          Alan Johnson
                          N4LUS
                          • drmdab
                            • Dec 2006
                            • 700
                            #14
                            I don't know anything about the beam direction, but they're using 200 kW currently.
                            • Digger
                              • Mar 2005
                              • 10097
                              #15
                              I sent an e-mail to WAZ asking for details of the transmission and got the exciting answer on the 6th of August:
                              Sehr geehrter Herr Isberg,
                              herzlichen Dank für Ihre E-Mail.
                              Wir haben uns erlaubt, Ihre Anfrage an die zuständige Fachabteilung
                              weiterzuleiten.
                              Mit herzlichen Grüßen
                              Ihr WAZ-Leserservice
                              ... let us hope that the "Fachabteilung" knows more...
