3930 kHz/ 3970/ 3950 kHz KRTPC
  • Filter
  • Time
  • Show
  • mitajohn
    • Nov 2002
    • 8439
    After the switch-off of the TDF-RFI DRM TX on 5865 kHz a DRM signal appeared on 5870 kHz, "KRTPC", Russian (?) speaking.
    Is this a new DRM transmission ?
  • drmdab
    • Dec 2006
    • 700
    #2
    Interesting catch. Found this post in a Finnish mailing list. Looks like it's a radio station (?) from Ukraine: http://www.krtpc.kiev.ua/index.htm
    Hope to see and hear them this evening on my receiver as well.
    • mitajohn
      • Nov 2002
      • 8439
      #3
      Feb. 04 (3930 kHz)
      Tonight I received this TX on 3930 kHz. Still on the air...
      • drmdab
        • Dec 2006
        • 700
        #4
        Indeed, it's on the air. Only some bursts of audio...
        @simone: Maybe you could move this thread to the log-section as this is a new broadcaster?!
        • sveron
          • Oct 2005
          • 147
          #5
          It seems that it's written "Kievska Filia Konzerny PPT" - the Kiev-based subsidiary of the RRT (the national transmitter network owner in Ukraine, according to the WRTH). The frequency list they seem to broadcast for both public and private broadcasters corresponds to the ones mentionned for Kiev in the WRTH too.
          Stephane
          Since 2022 : Gospell GR-228BP with long wire.
          Until 2015 : Laptop or Desktop PC with DWT and Degen DE31/TG33. Lower domestic QRN since 2010.
          • mitajohn
            • Nov 2002
            • 8439
            #6
            Feb. 05
            I detected "KRTPC" on 3930 kHz now on the air (16:00). I will post a log later.
            Log added.
            The signal was weak, just a bit over 0 meter with fading, low SNR and telephone sound quality.
            • mitajohn
              • Nov 2002
              • 8439
              #7
              Feb. 06
              I used the inside loop tonight. Better results.
              EDIT 00:45, still on the air...
              • FritzWue
                • Mar 2003
                • 6269
                #8
                3930 kHz KRTPC
                There is a new one in russian:
                • FritzWue
                  • Mar 2003
                  • 6269
                  #9
                  Some more info, they are transmitting some FM station.
                  • mitajohn
                    • Nov 2002
                    • 8439
                    #10
                    Feb. 07
                    @ Simone and all,
                    For 3 days now I am monitoring the transmissions of "KRTPC". I don't known if these are regular or test transmissions. I (we ?) don't know the TX site or even the target area etc...but I suggest you to open a new thread on "Reception Results - Recent Posts" and move/merge there all the relevant posts. Thanks.
                    • FritzWue
                      • Mar 2003
                      • 6269
                      #11
                      Hi John,
                      sorry for doubling.
                      Did a search for 3930 and found nothing...but we have a very good admin!
                      Signal was very weak this early evening:
                      • Digger
                        • Mar 2005
                        • 10097
                        #12
                        Here in Switzerland at 17:25 UTC KRTPC on 3930 kHz produces about +5 dBuV into my RX, 1-8 dB SNR, so all I get is the Label and not much else. I'll post a log later. Further, the transmission was hampered by intermittent talking in SSB in the channel plus occasional static noise blanking out the DRM signal.
                        • simone
                          • Jan 2003
                          • 10144
                          #13
                          A weak signal whenever I tried, typica results attached from tonight.
                          • tradio99
                            • Aug 2003
                            • 61
                            #14
                            Can somebody upload audio of received station on 3930 kHz? I suppose that it is not Ukraine, but Russia - presumably from Krasnodar. Audio sample I got last Saturday consists of 1-2 seconds portions, but with a big probability it is 24 hours russian news channel "Vesti FM"
                            KRTPC - 1 st letter of this abbreviation may be type of region in Russia " Kray"
                            in European part they have 2 these abbreviations for national network -in Krasnodar and Stavropol, please look at the link below
                            numbers 13 and 23 for the south of Russia (Юг России)
                            and they made in Krasnodar some DRM tests and preparations last year
                            Vladimir
                            • mitajohn
                              • Nov 2002
                              • 8439
                              #15
                              Feb. 09
                              Weak signal + fading + static + local noise and here's a 70 mins result.
                              @ tradio99, may be your are right. They announce Vesti FM and something like Kray....
