#61 |
DRM car radio
Osnabruck-A30-A31-Heek
#62 |
Nov. 04
A weak signal getting better towards time. Good results with low SNR, being out of the target area, using the loop to avoid the QRM.
Regards, John. |
#63 |
DRM car radio
1. Gladenbach-Marburg-Dagobertshausen
2. Marburg-Elnhausen-B255-B277-A45-Meinerzhagen No reception in the Dillenburg B277 tunnel. |
#64 |
Almost 100% decoding in this 68 minutes long log. The high SNR seems to be history now?
#65 |
DRM car radio
Bad Camberg-A3-A1-A43-Duelmen
#66 |
265 minutes of reception. Good or bad I can't say, as I think my whip had come loose from the antenna during the storm today. Well...
#67 |
Today's log looks much the same as yesterday's. Tomorrow I'll try my Roadstar instead. The log was mostly unattended.
#68 |
A test with two receivers on the same antenna. The Channel Impulse Response was not very good at the beginning. After 13 UTC the reception was perfect. I wanted to compare the two receivers, therefore I left out the bit after 13 UTC. The FRG-7700 performed better with 92% decoded audio; the Roadstar logged 72%.
#69 |
Another log comparing the FRG-7700 and the RF-B60, the latter with an improved 100 VAC power supply. Yes, in Japan they use 100 VAC, 60 Hz (where I reside, 100 V, 50 Hz a bit further east
#70 |
Great results for five hours today.
Simone |
#71 |
Quite good results in this (mostly unattended) 258 minutes long log. 99.6% decoded audio. The SNR with this receiver has improved with the new Power Supply. Hum in the DC affects both the active antenna and the receiver and the converter as well.
#72 |
Roughly the same result today, but the log is not as long as the previous one.
Oops, I had one more log from this morning too... Last edited by Digger : 22-11-2010 at 21:26. |
#73 |
278 minutes of good decoding. The Doppler curve is pretty rough.
#74 | |
Regards, Sarma ------------------ Elektor SDR 5/07- Elektor Preselektor - Miniwhip Antenna of PA0RDT |
#75 |
[quote=mvs sarma] 0.1uF capacitors across the diodes of the bridge...[quote]
Yep, I have practiced that since 1975 ! ![]() Today's Doppler log looks the same as the previous log of mine. Probably a propagation issue. The log is almost 4 hours long. Last edited by Digger : 25-11-2010 at 15:34. |
| Thread Tools | Search this Thread |
| Display Modes | |
