#1 |
Hi all
This QRG remain the same, and 13810KHz will be on air. from 8:03 and up to 14:00 UTC.
73 from: CT4RK Carlos Sines - Portugal Receiver TENTEC RX320 modified, R&S HEO10 active antenna, DREAM software...And...No more PLC/BPL QRM...Thanks ANACOM! Save the Radio Spectrum! Eliminate Broadband over Power Line. |
#2 |
4 hours and 41 minutes of almost perfect reception. The only problem was a weaker signal around 0940 UTC. The other blips in the log was caused by a 450 MHz TX on my work bench.
#3 |
Good signal here on this QRG (worse on the other frequency). But neither EPG nor Journaline data can be decoded. :-(
RX: Digital World Traveller Last edited by drmdab : 23-12-2008 at 13:40. |
#4 |
Good results except the dropouts due to the MDI problem.
Simone |
#5 |
Great results today (apart from the MDI feed problem).
Simone |
#6 |
Similar result here as Simone's, but I was not present. so I cannot tell exactly what happened. My log is 3h40 m long.
#7 |
Perfect! Excellent reception from DW/BBC on this QRG from Sines. 100 % CDA for 1 hour. Time: 09:24 - 10:25 UTC. The multimedia service is however not available.
73's Per - SM0ITS |
#8 |
Not always good.
#9 |
Seems there were again problems with the MDI feed all day, probably causing all the dips.
Simone |
#10 |
Yes, this is definitely no fun...
#11 |
Less problems today.
Simone |
#12 |
No problems today (seems the backup feed was used).
Simone |
#13 |
at least Sines still works ...
#14 |
52°N 07°E
DRM car radio
1. Hildesheim-A7-Goettingen
2. Goettingen-A7-Kassel - dropout at gasstop
Friedrich.....DK6QI.....JO31mw http://loudcity.com/stations/kansas-..._nowplaying=1# |
#15 |
52°N 07°E
DRM car radio
Limburg-A3-A67-A5-Offenburg
Had to stop and restart the car for several reasons, some dropouts then.
| Thread Tools | Search this Thread |
| Display Modes | |
