Old 09-12-2008, 12:03   #1
CT4RK
CT4RK's Avatar
Thumbs up BBC & DW on 13810 KHz from Sines
Hi all
This QRG remain the same, and 13810KHz will be on air. from 8:03 and up to 14:00 UTC.
73 from: CT4RK
Carlos
Sines - Portugal
Old 10-12-2008, 12:51   #2
4 hours and 41 minutes of almost perfect reception. The only problem was a weaker signal around 0940 UTC. The other blips in the log was caused by a 450 MHz TX on my work bench.
Regards, Terje
HED362
http://www.omnirep.ch/drm/
Old 10-12-2008, 13:17   #3
Good signal here on this QRG (worse on the other frequency). But neither EPG nor Journaline data can be decoded. :-(
RX: Digital World Traveller
Old 12-12-2008, 19:58   #4
Good results except the dropouts due to the MDI problem.
Old 13-12-2008, 14:50   #5
Great results today (apart from the MDI feed problem).
Old 13-12-2008, 21:22   #6
Similar result here as Simone's, but I was not present. so I cannot tell exactly what happened. My log is 3h40 m long.
Regards, Terje
HED362
Old 14-12-2008, 09:29   #7
Thumbs up Dec 14
Perfect! Excellent reception from DW/BBC on this QRG from Sines.
100 % CDA for 1 hour. Time: 09:24 - 10:25 UTC.
The multimedia service is however not available.
Old 01-05-2009, 20:55   #8
andimik
Not always good.
andimik is offline   Reply With Quote
Old 02-05-2009, 16:28   #9
Seems there were again problems with the MDI feed all day, probably causing all the dips.
Old 02-05-2009, 17:50   #10
Yes, this is definitely no fun...
Regards, Terje
HED362
Old 04-05-2009, 15:15   #11
Less problems today.
Old 05-05-2009, 14:52   #12
No problems today (seems the backup feed was used).
Old 11-06-2009, 13:30   #13
DRM-OM
at least Sines still works ...
Old 12-06-2009, 19:16   #14
52°N 07°E
DRM car radio
1. Hildesheim-A7-Goettingen
2. Goettingen-A7-Kassel - dropout at gasstop
Friedrich.....DK6QI.....JO31mw
http://loudcity.com/stations/kansas-..._nowplaying=1#
Old 16-06-2009, 18:24   #15
52°N 07°E
DRM car radio
Limburg-A3-A67-A5-Offenburg
Had to stop and restart the car for several reasons, some dropouts then.
