Old 25-11-2008, 15:22   #16
Perfect freq. and very good propagation.
One interesting detail every day sun go down DRM spectrum krazz and signal stringth go down. In this transmission from S9+40db to S9 under 10min.
So log is 103min.
Old 25-11-2008, 15:24   #17
Nov. 25 (BBC/DW Test 9545 kHz)
After the switch from Woofferton to Skelton the signal dropped by 10 to 15 dB,
then two AM QRM started at + and - 5 kHz producing a lot of decoding problems.
Old 25-11-2008, 15:57   #18
BBC & DW Test 13590 Sin
Perfect from Sines this afternoon. The drop-outs during the first 10 minutes were caused by me doing some measurements and adjustments on the 450/12 kHz converter.
Digger is online now   Reply With Quote
Old 25-11-2008, 17:34   #19
BBC & DW Test 3995 Skn
Almost perfect reception here too. The log is 144 minutes long.
Old 25-11-2008, 19:27   #20
DRM via sky wav on MW is not fan. Very slow selective fading give most mute of audio.
Old 25-11-2008, 20:13   #21
tradio99
BBC & DW Test 3995/1296 kHz
good reception on both frequencies this evening
Vladimir
tradio99 is offline   Reply With Quote
Old 25-11-2008, 20:44   #22
BBC & DW Test 5895 kHz Kvi
This transmission was not good at all here with strong AM slap-bang in the middle of the channel....
Old 25-11-2008, 20:46   #23
BBC & DW Test 1296 Orf
Not good at all here like most of the time. Strong AM in the middle makes decoding almost impossible. Grrr.
Old 25-11-2008, 21:10   #24
Nov. 25 (3995 kHz)
A 6 hour result. After switching at 18:00 there was a drop in the SNR figure.
Old 25-11-2008, 21:28   #25
5895 kHz KVI
Strange results using mode A, SDC indicator red all the time, no decoding possible, or maybe a Tx problem?
Old 25-11-2008, 23:40   #26
Not bad, I can decode some snippets of audio here even in far east Asia.
Also interesting DRM promo-trailer at the end of programme.
Old 26-11-2008, 04:12   #27
3995 kHz
Seems there is a problem with the HF MDI feed this morning, looks similar as on 5895 kHz yesterday.
Old 26-11-2008, 05:23   #28
BBC & DW Test 3995 Sin
At first there was nothing, then there was a label, but MSC and SDC were off.
Old 26-11-2008, 08:02   #29
Quite good results with a few droputs last night and this morning, I assume the two sync losses in the first hour last night were caused by work on the CS
Old 26-11-2008, 11:09   #30
BBC & DW Test 9545
Bad propagtion for DRM from Wofferton to my QTH. And AM on 9540 9550 and 1200UTC start AM on 9545 also !!!Now most i stop log.
Very strong signal stringth up to 64dbuV.
