BBC & DW Joint Test Transmission
  • Filter
  • Time
  • Show
  • mitajohn
    • Nov 2002
    • 8424
    A weak signal in a noisy environment with a chaotic IR gave the attached result.
    EDIT: A new thread has been opened for this test, please move the post there.
    Thanks.
    Post moved, Simone
  • Julian
    • Sep 2004
    • 37
    #2
    today, wed and thu BBC & DW will be testing a new joint schedule. The transmission schedule is as follows, please let us know how it works and what you like and don't like:
    HF
    Code:
    start  end  freq  Station  power  Azim  Antenna  days Prog  Mode  Audio Source
    05:00  07:00  3995  SINES  90  40  HR 1/1/0.50  1234567  BBC  B  ENEUR
    07:00  08:00  6130  SINES  90  45  HR 4/4/0.80  1234567  DW  B  DW02
    07:00  08:00  6195  SKELTON  100  150  HR 2/1/0.50  1234567  DW  B  DW02
    08:00  09:00  9610  SINES  90  45  HR 4/4/0.80  1234567  DW  B  DW02
    08:03  09:00  13810  SINES  90  30  HR 4/4/1.20  1234567  DW  B  DW02
    09:00  10:00  9610  SINES  90  45  HR 4/4/0.80  1234567  DW  A  DW02
    09:00  10:00  13810  SINES  90  30  HR 4/4/1.20  1234567  DW  A  DW02
    10:00  11:00  9545  WOOFFERTON  100  114  HR 2/4/1.00  1234567  DW  A  DW02
    10:00  11:00  13810  SINES  90  30  HR 4/4/1.20  1234567  DW  A  DW02
    11:00  12:00  9545  WOOFFERTON  100  114  HR 2/4/1.00  1234567  DW  A  DW02
    11:00  12:00  13810  SINES  90  30  HR 4/4/1.20  1234567  DW  A  DW02
    12:00  13:00  9545  WOOFFERTON  100  114  HR 2/4/1.00  1234567  DW  A  DW02
    12:00  13:00  13810  SINES  90  30  HR 4/4/1.20  1234567  DW  A  DW02
    13:00  14:00  9545  WOOFFERTON  100  114  HR 2/4/1.00  1234567  DW  A  DW02
    13:00  14:00  13810  SINES  90  30  HR 4/4/1.20  1234567  DW  A  DW02
    14:00  15:00  9545  WOOFFERTON  100  114  HR 2/4/1.00  1234567  BBC  A  ENEUR
    14:00  15:00  13590  SINES  90  30  HR 4/4/1.20  1234567  BBC  A  ENEUR
    15:00  16:00  9545  SKELTON  100  153  HRS4/2/0.60 S12  1234567  BBC  A  ENEUR
    15:00  16:00  13590  SINES  90  30  HR 4/4/1.20  1234567  BBC  A  ENEUR
    16:00  17:00  3995  SKELTON  100  121  HR 1/2/0.30  1234567  BBC  B  ENEUR
    16:00  17:00  5895  KVITSOY  35  190  LPH  1234567  BBC  B  ENEUR
    17:00  18:00  3995  SKELTON  100  121  HR 1/2/0.30  1234567  BBC  B  ENEUR
    18:00  19:00  3995  SKELTON  100  120  HR 1/1/0.30  1234567  DW  B  DW02
    19:00  20:00  3995  SKELTON  100  120  HR 1/1/0.30  1234567  DW  B  DW02
    20:00  21:00  3995  SKELTON  100  120  HR 1/1/0.30  1234567  DW  B  DW02
    21:00  22:00  3995  SKELTON  100  120  HR 1/1/0.30  1234567  DW  B  DW02
    22:00  23:00  3995  SINES  90  40  HR 1/1/0.50  1234567  DW  B  DW02
    MF
    Code:
    start  end  freq  Station  power  Azim  Antenna  bit/s  days Prog  Audio Source
    05:00  07:00  1296  ORFORDNESS  35  96  VM  101208  1234567  BBC  ENEUR
    07:00  17:00  1296  ORFORDNESS  35  96  VM  101208  1234567  off air
    17:00  18:00  1296  ORFORDNESS  35  96  VM  101208  1234567  BBC  ENEUR
    18:00  23:00  1296  ORFORDNESS  35  96  VM  101208  1234567  DW  DW02
    • Digger
      • Mar 2005
      • 10097
      #3
      BBC & DW Test
      A bit chaotic Impulse Response on 3995 kHz this morning, but a very good result anyway. According to the schedule above, the entire transmission came from Sines. However, there was a break at 06 UTC and after the break the SNR seemed a little bit lower that during the first hour.
      New Label: "BBC & DW Test"
      • Digger
        • Mar 2005
        • 10097
        #4
        BBC & DW Test
        BBC & DW Test on a new (?) frequency - 9610 kHz. Nearly perfect decoding on a clear channel. The log is 50 minutes long.
        • Sixten
          • Jun 2005
          • 3513
          #5
          Nov.24
          Perfect clear cannel and very strong signal stringth up to 74dbuV but little instabile propagation . CDA was 99.36% ok. MODE A is very good to my location if Ionospheric layers is ok.
          Log is 108min.
          • Digger
            • Mar 2005
            • 10097
            #6
            BBC & DW Test
            BBC & DW Test on 9545 kHz. Perfect reception for 60 minutes here. My National RF-B60 does not provide such a high SNR as the FRG-7700 does, but it works fine anyway.
            The second log is taken with the FRG-7700. The log is 70 minutes long and perfect.
            • Sixten
              • Jun 2005
              • 3513
              #7
              BBC & DW Test
              Prpoagtion very up and down from Wofferton and so start CRI on 9540 10db over DRM not so fan , listen to dropout.
              Log 68min CDA 92% for CRI .
              • Ager
                • Jun 2004
                • 69
                #8
                Just two clipboards here from DWT. Woofferton is good but Sines more stable as always. As seen in Sixtens log, reception of 9545kHz had some detoriation here too, about 12UTC, but Sines has remained 100% stable.
                It will be interesting to see the results of the DW/BBC cooperation.
                Anyway, it seems that Journaline is going to be lost.
                • drmdab
                  • Dec 2006
                  • 700
                  #9
                  Good results on 13590 kHz.
                  • simone
                    • Jan 2003
                    • 10144
                    #10
                    1296 kHz Orf
                    Interesting to see the new label this morning, similar results as usual as transmission parameters were basically the same as before.
                    • simone
                      • Jan 2003
                      • 10144
                      #11
                      6130 kHz Sin
                      Perfect results with a strong and stable signal.
                      • drmdab
                        • Dec 2006
                        • 700
                        #12
                        Sorry, just a short log for the new 9545 kHz with bad results.
                        • simone
                          • Jan 2003
                          • 10144
                          #13
                          9610 kHz Sin
                          Not too bad just using the DWT/whip antenna, no problems using mode A.
                          • simone
                            • Jan 2003
                            • 10144
                            #14
                            3995 kHz Sin (Skn?)
                            Some problems after the switching at 0600 (not sure if the second hour was from Sines as scheduled?)
                            • simone
                              • Jan 2003
                              • 10144
                              #15
                              9545 kHz Skn
                              Almost perfect results from Skelton.
