Old 14-04-2008, 12:52   #31
Very bad propagation today and strong splatter from 15335 to 15347 on S9.
Old 14-04-2008, 14:41   #32
I tuned over the frequency at 11:40 and noticed that there was a signal. I started logging, and the sad result is enclosed...
Old 14-04-2008, 16:34   #33
Only a weak signal today.
Old 15-04-2008, 21:30   #34
Today's result...
Old 17-04-2008, 14:04   #35
I'm afraid it looks more or less the same today too. Just some fragments of audio.
Old 17-04-2008, 14:51   #36
Very bad propagation today. Log is in 2 part for DREAM Krazz for very low signal. In part 2 of log I switch over to 2x10m INV.V last 30min.
But no difference. in signal !!!!!
Old 19-04-2008, 13:27   #37
Exclamation Frequency change
On 28/04/2008 the frequency will change for HCJB's transmission to Europe:
2000-2200 UTC on 15360 kHz.
Source: DX programme this morning on HCJB
Old 19-04-2008, 14:06   #38
Parts of the transmission were with audio but no sound.
99.7% CDA for 98 minutes is not bad.
Old 19-04-2008, 16:43   #39
Again a weak signal today.
Old 20-04-2008, 14:17   #40
99.5% CDA for 114 minutes
MSC was on, but there was no audio from 11:30 to 11:32 UTC and through the entire second/ german hour. Sound reappeared about 30 sconds before the end and switching off.
Everybody on holiday again?
Not sure, but maybe I got a local birdie on 13359.6 kHz, not good for the planned frequency change.
Old 20-04-2008, 17:13   #41
A weak signal and only silence when I tried to listen around 1200- 1230
Old 21-04-2008, 13:21   #42
Low signal but propagation give me 20min. in log, very splatter from AM on 15340 Khz.
Old 21-04-2008, 14:11   #43
Not good today, here also a lot of interference from wide AM signals on the lower side:
Old 27-04-2008, 20:01   #44
Bad results this weekend.
Old 28-04-2008, 13:20   #45
Very bad progation extremly low signal stringth below 5uV. from my INV.V 2x10m with 600 ohms feeder. Log is 54min .
