Old 11-08-2007, 12:55   #1
Question DRM via satillite?
Hi!
I know that some 'finished' DRM signals get to the relay-stations via satellite.
E.g. the Deutsche Welle DRM stream (Audio, label, Journaline, headlines as textmessages...) is generated in Bonn and finally broadcasted via Hotbird to the transmitter station.
So what I'd like to know: How to receive these "DRM-Feeds" on Hotbird? Has anyone discovered the frequency?
I even found some feeds on Hotbird wich maybe are used for relays:
13 East
GBTS 1 at: 12597, SR 27500, V, Audio and PCR PID: 2130 (two audio channels)
GBTS 2 at: 12597, SR 27500, V, Audio and PCR PID: 2173 (two audio channels)
The next feeds are used by VT Communications:
VTCSW1 at: 12597, SR 27500, V, Audio and PCR PID: 2029
VTCSW2 at: 12597, SR 27500, V, Audio and PCR PID: 2021
There is even a Deutsche Welle feed:
DWFEED-1 at: 11604, SR 27500, H, Audio PID 2162, PCR PID 133
But no DRM...
So I'm still looking for the DRM feed. Any clues?
Greetings
Old 13-08-2007, 20:16   #2
andy.chance
andy.chance's Avatar
http://www.ebu.ch/en/technical/trev/...06-drm_bbc.pdf has some info on satellite distribution for DRM.
Andy.
andy.chance is offline   Reply With Quote
Old 14-08-2007, 15:07   #3
richard
Does anyone know whether it would be possible to use a satellite for DRM transmission directly to a portable radio?
I have read that the early Russian Sputnik satellite produced a signal HF. Does anyone know whether you could make a signal from such a satellite high enough in level to receive indoors, without having to use a special directional receiving antenna?
Richard
richard is offline   Reply With Quote
Old 16-08-2007, 19:46   #4
leo
DW
The 10 DW radio are on 13 E
11604 H
See the link
http://www.lyngsat.com/hb6.html
Normally it is always in DVB -S.on sat .
At the transmitter they put the stream in the DRM muxer
leo is offline   Reply With Quote
Old 16-08-2007, 20:17   #5
11604 H
See the link
Hi Leo,
actually for DW the DRM stream is not available there as DVBS audio.
Also the multiplexer is not always at the Tx site. Some stations distribute the MDI stream to the Tx sites as described in the link that Andy posted above. Otherwise they could not operate an SFN.
Old 17-08-2007, 12:43   #6
Post
Now I know how it works:
Thanks to Mr. G. in Bonn
Hotbird 8 13E - 11.604 GHz-H
There is a data-stream which is assigned to the channel DW01 (German) Service-ID 3510, PID is 2510. Two MDI streams are broadcasted, 224.1.1.1 and 224.1.1.2, port 8888.
Old 17-08-2007, 13:57   #7
leo
DW on sat
For the moment the signal on 13810 is from DW 1 on Hotbird
I have make a scan of the stream DW on Hotbird.
There are other signals not see on a normal
DVB-S receiver
DW FM02: AP2120 PMT 278
DW FM03: AP2130 PMT 279
DW FM04: AP2140 PMT 280
DW feed1:AP2162 PMT 285
DW FM07:AP2158 PMT 282
DW FM06:AP2154 PMT 286
All in DVB-S
I know there are other transmission not in DVB-S
but they are private
