Old 10-10-2007, 22:56   #331
Originally Posted by Digger
PS: By the way Friedrich, what happened around 18:47 ???
There was a fast UFO blocking the beam over the atlantic.
Old 11-10-2007, 20:06   #332
Good and without dropouts until condx started to fade away.
Old 12-10-2007, 20:05   #333
12th Oct.
Well, the first 15 minutes were quite good, then the heavenly mirrors gave up...
Old 13-10-2007, 06:33   #334
Oct. 12
Not even a signal trace here.
Old 13-10-2007, 10:27   #335
Telspace
Oct. 12th log
Denis
Telspace is offline   Reply With Quote
Old 16-10-2007, 19:46   #336
16 Oct.
Hi Mathias and all.
Very good signal stringth from start, and i make a short test under 2 min, from my portabel reciver and telscopic antenn . I pick up SNR9db Wov .
Signal fade out 1940UTC .
Old 16-10-2007, 20:02   #337
Less luck down here... only 49% CDA.
Old 17-10-2007, 20:21   #338
17th Oct.
The first 5 minutes were 100% OK, but then the 1st hour added up to a sad 67% CDA. Then it was downhill all the way. The conditions just are not there.
Old 18-10-2007, 20:15   #339
Wow, it could become even worse than yesterday. It seems that the season is drawing towards the end for Santiago to Europe in 17 MHz.
Old 19-10-2007, 22:29   #340
19th Oct.
Well, no further comment. OK, so I shortened the antenna a little, but the SWR became a lot better on this frequency. Anyway, today's unattended log takes the price.
Old 23-10-2007, 20:07   #341
23rd Oct.
Tonight there was nothing much at all...
Old 23-10-2007, 20:09   #342
...here excellent result tonight, dropouts in the middle caused here
audio level was a little low
SNR seems to be TX limited
Old 24-10-2007, 19:09   #343
The season seems now definitely to be over for 17 MHz from Santiago...
Old 25-10-2007, 20:37   #344
25th Oct.
The conditions this evening are quite funny peculiar: While 3.9 MHz did not work at all for a while from 2000-2030, CVC came in loud and clear in the 17 MHz band from 1847 - 1956 with nearly 100% CDA! The overall CDA ended at 61% because the weak signal in the beginning. Perhaps the solar wind has something to do with these conditions...
Old 26-10-2007, 19:03   #345
Oops, got stuck in front of the TV and forgot to start the log. Anyway, I did not hear anything at the beginning, so I just left. Therefore I have no idea how much and how long the fun lasted...
The screenshot is taken at 1850 UTC. There was absolutely no signal to hear at that time...
