Old 09-04-2007, 18:49   #1
mathias_s
mathias_s's Avatar
CVC 17640 kHz from Santiago
Dear all,
Thanks for all reports. I have seen very good results!
As you have noted, we are running on a new frequency, 17640 kHz.
Reports and comments are welcome here as always.
Many thanks
Mathias
Mathias
mathias_s is offline   Reply With Quote
Old 09-04-2007, 19:13   #2
Apr. 9
The propagation conditions tonight helped for an almost excellent result for 60 mins.
Old 09-04-2007, 20:09   #3
Rather impressing reception here tonight for two hours.
Old 10-04-2007, 19:55   #4
Apr. 10
A very good to nearly excellent result again tonight until the signal lost.
Old 10-04-2007, 20:07   #5
A bit up and down in the beginning, but from 1830 UT things improved dramatically. The rest was almost perfect here.
Old 11-04-2007, 19:56   #6
Apr. 11
Some starting problems then nearly excellent results until the signal disappeared.
Old 11-04-2007, 20:09   #7
Thumbs up 11th April
The signal was a bit weaker tonight. Thanks for the bit rate change from 20.96 to 17.68 kbps around 1807 UTC. I think 11000 Hz max audio is perfectly enough for the programme. Even that I had signals <S5 at times (usually I cannot get any solid decoded audio with that) the >98 % decoded audio for the whole transmission was very good. Some peculiar (but short) audio dropouts I believe were caused because of the blurred Channel Impulse Response, which became worse later in the transmission.
Old 11-04-2007, 20:25   #8
A short but perfect log of the last 14 minutes. Btw I do not tune in so often, but again today I noticed this frequency offset that I mentioned a few times in the past, seems nothing has changed. Any idea about this problem Mathias?
Old 12-04-2007, 06:37   #9
11 Apr.
Propagation from Santiago to Sweden was very bad last days. I have 3 antenna very good for this band. Dipole 10m up ,8m vertical gama tuned just now for 17.6Mhz and inv. V 2x20m and 600 ohms feeder . But very small part of signal can be heard in my QTH. Only last 15min ,play very good for low signal stringth. Now CDA ok from S3 and SNR17db . But from 20,96kbps min. S5 and SNR15db . So I hope propagation came back agin.
Thanks Mathias.
Old 12-04-2007, 20:04   #10
A very weak start, but then it picked up, just to disappear when it was at its best. Only the carrier was left
After a long break the DRM signal returned only to disappear too soon again, this time the carrier disappeared as well.
Btw, you could enjoy CVC La Voz in AM a bit up the scale on 17.680 MHz
I guess today was not a lucky day...
Old 13-04-2007, 19:26   #11
Apr. 13
Some problems at the beginning then nearly excellent results until the signal disappeared, 19 mins earlier than on my 11th April report.
Old 13-04-2007, 19:49   #12
Friday 13th April
Not so strong signal in the beginning, but thanks to the 17 kbps quite a lot (>97%) decoded audio. Then between 1814 - 1838 UTC the signal dropped and the decoded audio sank to 85%. Then again between 1842-1916 UTC I recorded >99 % decoded audio. Then due to a TX failure the transmission ended.
Old 13-04-2007, 19:57   #13
some acceptable parts until the TX failed.
Old 16-04-2007, 20:05   #14
16th April
A late start at 1807 UTC, then the signal strength quickly improved. From 1818 UTC until the end it was more or less perfect with 99.5% Decoded Audio. The RF signal peaked S9+5 dB (about +40 dBuV) just before the end of the transmission.
Old 16-04-2007, 20:16   #15
Apr. 16
Weak signal and QRM tonight, so not good results in contradiction with my previous reports.
