#1 |
RNZI 9890 kHz
Hi All
I actually managed to listen to NZ's own DRM signal today ![]() Normally RNZI's signals are undecodable here in Wellington. Cheers, Chris
Elad FDM-S1, AOR AR-7030, FRG-100/DRM receivers + longwire antenna http://www.owdjim.gen.nz/chris/radio/DRM/ |
#2 |
Very good signal from RNZI this morning. Log is 55min. and CDA 99% ok. Strong and stabil signal from my home made BBA20 brodband antenna . ![]() |
#3 |
Very strong signal strength, cannel free from QRM. Log 1 . 0900-1100UTC Log 2. 1100-1200UTC ![]() |
#4 |
Not at all like that in Switzerland. Hampered as usual from a weak signal in the beginning, CZ started +10 kHz at 11-1130 UTC roughly. 20 minutes of some kind of listening was possible... Terje |
#5 |
Location: ZhongShan, about 100km N.W. of HongKong in SE China
I noticed they use 9890 kHz for the 1100 - 1300 UTC period now. EEP coding scheme is also replaced with UEP, but I didn't find the distinctive hierarchy data structure in the log file. Did I miss something?
BTW: the drop out during 1155-1200 UTC is due to household electric device interference. |
#6 |
Her is log of 60min. very good signal. 1200UTC start strong AM on 9890 and 9895Khz . |
#7 |
I logged from 0702 UTC, but cut the log short as there was absolutely nothing to hear until 1150 UTC. The last hour was not bad despite carriers -5 kHz, on channel and +5 kHz towards the end of the transmission. Terje |
#8 |
MOBILE RECEPTION
Gescher-A31-A2-Gelsenkirchen
Second half was logged in Gelsenkirchen under the powerlines of the streetcars etc.. |
#9 |
18 Nov log
Virtually all of the broadcast for my overnight period. Rather a lot of downtime, but since I was sleeping, I don't know what was causing the fairly large drops in overall signal quality.
Most likely adjacent analog stations.
73 Brendan WA7HL Bisbee AZ 31-27N 109-45W / DM51ck RX320D using KB7GF's 36"/106cm external loop |
#10 |
Hi.
Good signal strength today . no QRM from NL.So log 65min. to end of transmission. ![]() |
#11 |
20 Nov log
There are some fairly big dropouts on this broadcast - I haven't the faintest idea what caused them.
#12 |
21 Nov log
Very much in and out tonight. Not a lot of reliability on the circuit between my QTH and NZ. Dream was "stuck," so I had to terminate the log early.
#13 |
Good signal strength today ,but only to 1200UTC ,now start strong AM station on 9885 and 9895Khz. ![]() |
#14 |
Today's contribution. Towards the end of the transmission the signal was hampered from co- and adjacent AM channels. |
#15 |
Junior Member
Amazing results for me (keep in mind the antenna used in this case is indoor!).
Co- and on-channel interference as described by Sixten becomes stronger and stronger during the last hour. Seems I started my log too late, as best results were right in the beginning. |
| Thread Tools | Search this Thread |
| Display Modes | |
