Old 11-10-2006, 16:08   #1
6015 kHz TDP from Issoudun
Salut Jacques, Ludo,
perfect reception today, configuration without textmessages.
Old 11-10-2006, 16:21   #2
.. and here is a typical example of the IR.
Old 11-10-2006, 16:31   #3
lmaes
lmaes's Avatar
A report from Belgium. Starting a little bit earlier when apparently some testing was going on.
Ludo
TDPradio - www.tdpradio.com
DRMstereo - www.drmstereo.com
lmaes is offline   Reply With Quote
Old 11-10-2006, 16:34   #4
Baldo34
Baldo34's Avatar
I did no log, but reception was excellent.
73, Klaus
Equipment: Winradio WR-G303i
DX-10 active antenna
http://www.drm-dx.de
Old 11-10-2006, 19:31   #5
f1tay
Reception at Paris.
Daniel
Old 11-10-2006, 21:03   #6
sveron
sveron's Avatar
11 october
Hello to all,
No logging today, I just tried reception at different times. It was always good (means always audio with short dropouts), around 18dB SNR on the laptop running on AC power, and Degen DE31 antenna -which was plugged to my Digital World Traveller, but not set properly at the window and not put on ! That means the signal is strong here at the south of Strasbourg.
I noticed first test without any sound, then the TDP programme. Happy birthday to TDP Radio anyway !
73, de Stephane
sveron is offline   Reply With Quote
Old 13-10-2006, 16:14   #7
lmaes
lmaes's Avatar
Apparently, some technical problems today. Last 15 minutes were OK.
Friday the 13th?
Ludo
Old 13-10-2006, 16:29   #8
... and configuration looked like Juelich in the past, was this really from Issoudun?
Old 13-10-2006, 18:15   #9
Similar results as Ludo.
Old 13-10-2006, 21:10   #10
F6AJW
Sorry, I confirm Friday 13th transmitter problem now cured.
DRM parameters were changed followind TDP request. Simone, what about Service Id, correct?
Regards.
Jacques
F6AJW is offline   Reply With Quote
Old 16-10-2006, 19:40   #11
Quite good again today, dropouts probably due to too much multitasking on the PC
Old 17-10-2006, 16:07   #12
Great results, just two parallel lines
Old 17-10-2006, 17:18   #13
GRUSON
Merci beaucoup Simone!
Jacques
GRUSON is offline   Reply With Quote
Old 18-10-2006, 16:13   #14
pretty good again today.
Old 18-10-2006, 16:43   #15
Baldo34
Baldo34's Avatar
Hello Jacques and Ludo,
reception was excellent with the Morphy Richards. btw the telescopic antenna was not extended.
73, Klaus
