Old 22-09-2006, 07:19   #1
Baldo34
Baldo34's Avatar
TDF 6015 kHz from Issoudun
there is a DRM-test right now on 6015 kHz with the label "TDF ISS 11.845".
No audio so far.
See screenshot.
73, Klaus
Equipment: Winradio WR-G303i
DX-10 active antenna
http://www.drm-dx.de
Old 22-09-2006, 11:36   #2
f1tay
Report TDF 6015 khz.
About 11h20 QRM by test of VT Merlin Communication in AM.
Les test de TDF en DRM sur 6015 khz sont complétement interférés depuis environ 11h20 T.U. par un test en AM analogique de VT Merlin.
Daniel
File Type: txt DreamLog TDF 6015.txt (473 Bytes, 65 views)
Old 22-09-2006, 12:31   #3
Baldo34
Baldo34's Avatar
At 1230 UTC the label is correct: "TDF ISS 6.015"
73, Klaus
Old 22-09-2006, 15:37   #4
f1tay
VT Merlin in analogic AM is broadcast for Issoundun.
Log of reception at Paris.
Comme il s'agit d'essais il y avait des coupures d'éméteur, des passages en analogique (la bande annonce de VT Merlin) etc... ce qui explique la non réception par moment sinon la réception ici était parfaite.
Daniel
Old 25-09-2006, 07:13   #5
Baldo34
Baldo34's Avatar
Strong signal this morning at my location.
See screenshot.
73, Klaus
Old 25-09-2006, 14:39   #6
Baldo34
Baldo34's Avatar
Issoudun now (1430 UTC) with TDPradio. 100% audio, no problems so far.
73, Klaus
Old 25-09-2006, 14:40   #7
Not bad at the beginning with the lower bitrate, later 20.9 kbps, param. stereo with many dropouts but also the signal was weaker then.
Old 25-09-2006, 15:09   #8
Good results this afternoon, label was TDF but it sounded like TDP
Old 25-09-2006, 15:10   #9
f1tay
Report of TDF 6015 khz.
Old 26-09-2006, 14:36   #10
sveron
sveron's Avatar
26 september 2006
Hello to all, bonjour,
Very good reception this afternoon here, stable and around 23dB SNR with the laptop working on batteries only. Few SNR/audio crashes due to switching between batteries and AC power on my laptop, and also trying different antennas, so the overall result might be virtually around 100% decoded audio.
All bands are blocked here except BBC on 7320, and very low VoR on 9450 and DW on 15440, so it is a good surprise. TDP programming with only 13kHz audio bandwith, good enough to avoid codec artefacts, I prefer that to more bandwith and distorsion.
Bonne réception d'Issoudun ici en Alsace sur les 49m, c'est l'un des rares émetteurs à passer ici cet après-midi en raison de perturbations sur toutes les bandes (locales ou non). Dans l'attente d'autres tests depuis la Guyane :-)
73, de Stephane
Laptop with DWT and Degen DE31/TG33. High domestic QRN.
sveron is offline   Reply With Quote
Old 26-09-2006, 15:08   #11
Quite good results this morning.
Old 26-09-2006, 15:16   #12
lmaes
lmaes's Avatar
Reception in Belgium between 12 and 15 UTC. Not perfect but good.
Ludo
TDPradio - www.tdpradio.com
DRMstereo - www.drmstereo.com
lmaes is offline   Reply With Quote
Old 27-09-2006, 11:02   #13
lmaes
lmaes's Avatar
Reception of 6015 kHz this morning, quite poor in Belgium.
Ludo
Old 27-09-2006, 15:45   #14
0700- 1500
Quite good here during the whole transmission.
Old 27-09-2006, 19:16   #15
lmaes
lmaes's Avatar
The second part of my monitoring for today. Not so good!
Ludo
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
