#1 |
OldieStar Radio on 1575 kHz
new DRM station in Germany: OldieStar Radio on 1575 kHz from Burg. See screenshot. 73, Klaus
Equipment: Winradio WR-G303i magnetic longwire balun (12,5 m) DX-10 active antenna http://www.drm-dx.de |
#2 |
Transmission times in DRM on 1575 kHz are 0800-1400 UT with 20 kW and 2200-0400 UT with 100 kW.
At the other times the frequency is used by VoR in AM. 73, Klaus
#3 |
Strong signal, but an impulse response as long as the chineese wall.They use the wrong antenna type at night. Around 12 db and no audio. No AM Interference is visible.
regards, Carsten AOR 7030 + Wellbrook ALA 1530P & DWT + Degen DE31 + TG33 Free DRM Tools for analysing, controling and automating your DRM reception and logging |
#4 |
Bad results, not very strong signal and co-channel interference in the last hour this morning, also something was wrong with the audio feed!
Simone |
#5 |
A bad result
Quite a bad result this morning with a long impulse response and in addition on-channel interference which could not be nulled.
OFDM symbols were transmitted but without audio. See screenshot for spectrum, WMER and impulse response. Roland |
#6 |
Log
And here is the log.
Roland |
#7 | |
Hi Roland, there was audio but very low level see attachment, with speakers set to maximum I could hear some music. Simone |
#8 | |
Well, I didn't hear any with speakers adjusted for normal but low audio levels but I was also busy trying to find an optimum loop position but to no avail... I have read that an NVIS antenna is used and the results are exactly of the kind that I expected. I think one should forget about DRM and NVIS antennas, they just don't fit together. Roland |
#9 |
Not much, but a signal for me:
#10 |
At night
At night, the impulse response looks even worse than it did in the morning when it was not completely dark anymore.
Not much audio can be decoded from a signal with so many echoes. If audio can be decoded, it is only barely audible even if all volume sliders are fully up here. Roland |
#11 |
August 8
Not worth further logging.
Roland |
#12 |
Bad results again, a weak signal and co-channel interference.
Still the audio problem with extremely low audio level. Simone |
#13 |
This is what I get with my Aircoil:
#14 |
Signal can be seen
but nothing to be heard WDR on 1593 works better - and is in similar distance with less power ... |
#15 |
August 9
Reception of the DRM signal as such was much better than on the days before. However, interference was often strong and although the interfering carrier was only a few dB above the averaged DRM signal, it still did cause a deep notch in the WMER vs carrier plot.
A lower bitrate at a better protection level (B/A = 0/0) might improve the situation. The impulse response was considerably shorter than on the days before, it still had a lot of peaks but their amplitudes fell off much faster than before. Were there any changes on the antenna used at night or was it just a change in propagation that made the difference? The audio problem was unchanged so it was / is still impossible to listen to normal audio. Roland |
| Thread Tools | Search this Thread |
| Display Modes | |
