Old 30-10-2005, 07:33   #1
Voice of Russia on 12060 kHz
first short log of VoR on 12060. In first impression this frequency is not as good as 15780. On 12055 is a station in Chinese? language.
Old 30-10-2005, 13:24   #2
First log on 12060. A good result for one hour in spite to the strong interference on the left edge of the spectrum. See log file.
John.
Old 30-10-2005, 14:26   #3
Noticed the change this morning. I didn't even bother logging, as the signal was so messy so it wasn't worth the effort.
Old 30-10-2005, 14:44   #4
Jos
12060
Results for today.
Kind regards.
Jos
Jos is offline   Reply With Quote
Old 31-10-2005, 17:49   #5
MOBILE RECEPTION
Driving from 48712 Gescher via A31, A3, A52 to 40477 Duesseldorf center.
Same way in other direction in the afternoon here:
http://www.drmrx.org/forum/showthrea...2261#post22261
http://www.mar1386.com
Old 31-10-2005, 22:13   #6
Hi Fritz,
Thanks goodness for www.worldmap.com so I know where you're whizzing through....
Hi Fritz,
I am lucky enough only to have to go down the stairs to my QRL... - I do not miss the 150 odd kms everyday I had to drive.... Getting old, I think...
Old 31-10-2005, 22:37   #7
Hi Terje,
thanks for the link, I use klickTel if I want to find a town by postcode.
I simply drive to work and back home and let DREAM do the job.
Old 02-11-2005, 12:12   #8
A short report on 12060 (2nd graph) compared to my previous one (1st graph).
John.
Old 05-11-2005, 10:57   #9
Here is the today's result on VoR.
John.
Old 06-11-2005, 12:08   #10
Jos
12060
Good results inspite of the antennabeam of 240°(normally 260°)
Kind regards.
Jos.
Old 06-11-2005, 12:23   #11
Good results except during the last 15 minutes when somebody tested 5kHz down with a strong carrier switching a single tone modulation on and off.
Old 09-11-2005, 18:15   #12
MOBILE RECEPTION
Good results driving from 48712 Gescher to 44269 Dortmund, only one longer dropout in a tunnel.
Old 12-11-2005, 13:13   #13
Andreas
Junior Member
Andreas's Avatar
Today I found out, that local interference, caused by low-voltage lighting equipment near the indoor (!) antenna can heavily disturb DRM reception - which can be seen for approx. 30' shortly after start of my
log.
On the other hand AM interference from 5 kHz below, appearing during the last hour or so made the signal unstable, but did not yet cause drop-outs.
Is it really Radio Rossia on 12055 interfering? Would be a bad bad joke !
Andreas is offline   Reply With Quote
Old 16-11-2005, 12:37   #14
30 mins with VoR, not a bad result.
John.
Old 16-11-2005, 15:33   #15
quite good results, no audible dropouts although the graph from DRMSWR does not look perfect.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
