Old 15-08-2010, 20:00   #61
The Tx update should be working OK again, so it should not be necessary anymore to edit the drmtx file, please let me know of any problems.
Old 16-08-2010, 02:11   #62
Siber
Siber's Avatar
I also had some problem with the Tx update. It's OK now.Thank You Simone.
Siber is offline   Reply With Quote
Old 02-08-2014, 10:16   #63
Mikey
Does anyone know how or if I can get this to log recordings using DREAM and my Dongle?
Old 03-08-2014, 02:38   #64
Hi Mikey,
The author of DRMCalc has, as far as I know, not responded (in this forum) to any questions in the recent past.
As a preferred alternative why don't you try out Terje's program that does much more (he is available on this site and currently posting under the pseudonym "Digger")?
I've been very pleased with the program - I urge you to try out:
http://www.hobbyradio.se/en/drm/drmlogplot_en.html
Old 09-08-2014, 06:30   #65
richardinprague
Newstar measurements
I've always be puzzled about Newstar`s "MER" measurement.
Doesn't this mean Mean Error Rate?
If so, how can a RATE be expressed in deciBels, which is usually a RATIO expressed logarithmically? What is MER actually measuring?
Grateful if anyone can clarify for me.
All the best
Richard+?
richardinprague is offline   Reply With Quote
Old 09-08-2014, 07:02   #66
O.T.
Hi Richard,
According to the Broadcast user's manual it means "Modulation Error Ratio (MER)":
"The MER indicates the ratio between the wanted vector and the error vector and is normally expressed in dB. Thus a high MER figure shows that the error vector is small compared with the wanted vector and in consequence there should be little difficulty in correctly decoding the data represented by the carrier phase and amplitude. For a compliant DRM transmitter, an MER of 30dB or greater should be expected."
Old 10-08-2014, 06:30   #67
richardinprague
Originally Posted by Digger
Hi Richard,
>>Many thanks for your very clear reply, "Digger"! Now I understand what it means and how it's measured :-)
Regards
Richard<<
