#16 |
Yes ! like that, very nice.
John. |
#17 |
52°N 07°E
Another try:
A bright/white background makes the human iris to contract. Therefore dark lines on bright background always appear clearer than bright lines on dark/black background. simple but true ...perhaps some members better don't want a clear view of their results. ![]()
Friedrich.....DK6QI.....JO31mw http://loudcity.com/stations/kansas-..._nowplaying=1# |
#18 |
Overwrites PNGs
When capturing the same QRG twice on the same day, the previous file is overwritten. Of course there is a workaround but couldn't it be possible to ask for a different filename before overwriting? Terje |
#19 |
Hi Terje,
I added the starttime in filename between Date and username. But DRMcalc has now a much more difficult problem. How to cchoose the correct site for 5875 khz from Rampsiham and Norway, both labeled with BBCWorldService? ![]()
regards, Carsten AOR 7030 + Wellbrook ALA 1530P & DWT + Degen DE31 + TG33 Free DRM Tools for analysing, controling and automating your DRM reception and logging |
#20 |
Hi Carsten,
today as a workaround I just edited the drmtx file and use 5875 for KVI and 05875 for RMP until there is a better solution to the problem Simone |
#21 |
Hi Carsten,
As an amateur VB programmer I understand your feeling. The more the merrier.... (?) Arrrgh. ERR 99999 Nah, I'd save the first file for now, and then move into a different folder and then save the new one, re-label it until you find a solution... 73 Terje PS: Still a bit unhappy with the pitch black background ... sri... |
#22 |
I just uploaded the brandnew version 4.1 of DRMcalc. Changes and new features are:
- fixed bug in distance calculations for users with south and/or west coordinates - fixed graphic errors in screen resolutions greater than 96 dpi - removed colors from labels - changed application background to white for printing - added selection box for TX sites on same QRG with same label - show TX location name in statusbar if possible - added start time in filename for screenshots and text exports - added colorized graph legend - introduced history file - improved About dialog - changed some typings - added site names in drmtx.txt Free download as usual here: http://home.arcor.de/carsten.knuetter/drm.htm
#23 |
Hi Carsten,
Great new version thanks. I have found a bug which is so obscure I feel embarrassed to report it .If Dream logging is enabled/disabled for less than a minute there is no detail record written - only a header/footer. In DRMCalc the window and some stats eg TX distance are then not refreshed, but previous values are still displayed. regards Bob
Winradio G303Pro, RCA AR-88D/Sat-Service Schneider LC mixer, plus Wellbrook LA5030 Indoor Loop, longwire antenna |
#24 |
I just uploaded the brand new version 5.0 of DRMcalc. It is the power edition for power loggers
Changes and new features are: - 10 user profiles for quick change of topic line with e.g. different RX and antenna configurations - up to 100 remarks could be inserted into the graph with a left mouse click while pressing the ctrl key - fixed bug displaying wrong TX site if choosen by label - show message if log file contains no data - removed "Compare different days" checkbox, job is done now by DRMcalc itself - increased accuracy of displayed CDA value - limited displayed CDA value to 100.00% - small GUI adjustments Free download as usual here: http://home.arcor.de/carsten.knuetter/drm.htm
#25 |
Hi Carsten,
Bravo! But why do the comments remain when you change logs? And how can you read the comments at the very left and right borders of the chart? 73 Terje |
#26 |
Hi Terje,
text out of borders will be no problem anymore in the next version, please see attached screenshot. If you add a remark, DRMcalc gives you 3 Options. One of them is "Delete all". Or just uncheck the "Show remark" checkbox.
#27 |
Hi Carsten,
I'm a nit-picker, I know. But I know, once you start programming there will be NO end. Thanks for the good work. Terje |
#28 |
Hope that this is the last update for this year.
DRMcalc 5.1: - fixed out of border remarks Free download as usual here: http://home.arcor.de/carsten.knuetter/drm.htm
#29 |
The old comparision engine of DRMcalc had quite a few bugs. So I had to redesign the whole engine. I hope that it will work now correctly in all possible cases. If you still find some mistakes, please send me the two log files.
Important for Dream users: Please make sure that your receivers coordinates are saved in the dream.ini file! I removed the storage of coordinates for Dream in this version. It was more confusing and is not really needed anymore, because Dream is able so save the coordinates since a long time now. These are all the changes in 5.2: DRMcalc 5.2: - total redesign of the comarision engine, because the old one had serveral bugs - added time of remark in the remark text - tx site identification improved - removed the option of displaying the distance in miles instead of km - detection of log files from Winradio - removed storage of coordinates for Dream (coordinates are saved in the dream.ini, please put your coordinates there if not done already) - message for invalid coordinates - enlarged tx site statusbar window - enlarged tx site selection window Free download as usual here: http://home.arcor.de/carsten.knuetter/drm.htm
#30 |
Hi Carsten,
as my computer is quite slow could you make it 600 by 800? Paul |
| Thread Tools | Search this Thread |
| Display Modes | |
