Old 13-11-2005, 18:36   #316
The hickupping person doesn't get his throat cleared because it seems to be throttled, ie bandwidth is only about 9.6 kHz, see attachment.
Does he say "family structure"?
Old 13-11-2005, 19:12   #317
I "love" totally automated stations with no human being around to fix this. What a luck that there are still no DRM Radios in the stores, so nobody will take a note of this.
Old 13-11-2005, 19:40   #318
I really miss the music from the WOMAD music festival which would have been broadcast today.
Old 13-11-2005, 21:33   #319
jbriggs
James Briggs
jbriggs's Avatar
Sorry for the fault, we never saw this one before, so it is important to find out the cause rather than simply rebooting all the equipment. It could be at the studio or transmitter site, as from the description it is not obvious what is the cause. So it will be fixed in the morning once we find out exactly what the cause is.
jbriggs is offline   Reply With Quote
Old 13-11-2005, 21:41   #320
Originally posted by jbriggs
... so it is important to find out the cause rather than simply rebooting all the equipment.
If the scheduled end of transmission at 23:00 UTC will not clear the current state as well ...
Or is it just the TX that is switched off?
Old 14-11-2005, 04:11   #321
Hi James, all,
the problem ist still the same at the beginning of the transmission this morning, so good for investigating what´s causing the problem.
Old 14-11-2005, 08:12   #322
jbriggs
James Briggs
jbriggs's Avatar
Hi Roland, it looked like a software fault rather than any transmitter fault, so I was expecting the same fault this morning. In fact it seems the Thales Modulator PC at Orfordness has crashed so the fault was at Orfordness.
Old 14-11-2005, 17:11   #323
52°N 07°E
MOBILE RECEPTION
Orfordness working again this afternoon.
Driving from Osnabrueck to 48712 Gescher.
The short vertical antenna ontop of the car is good at low elevation, so some early problems with onchannel AM interference. The AM carrier was often visible, probably from Spain.
Friedrich.....DK6QI.....JO31mw
http://loudcity.com/stations/kansas-..._nowplaying=1#
FritzWue is online now   Reply With Quote
Old 14-11-2005, 22:38   #324
Nov. 14
on-channel carriers were strong (with the signal from Valencia perfectly nulled) and there were a lot of fading periods causing many dropouts.
Local interference level was low.
Old 15-11-2005, 05:20   #325
strong and stable signal (except the first 10min), perfect results, see attachment
But seems to be the wrong datastream at the start this morning (RTHK)!
Old 15-11-2005, 22:15   #326
Nov. 15
there were some problems with a long impulse response tonight. Local interference level was low and I have no idea what caused the sudden improvement in reception that can be seen in my log.
Old 16-11-2005, 05:18   #327
great conditions last night, nearly perfect results, see attachment
Old 16-11-2005, 19:55   #328
52°N 07°E
MOBILE RECEPTION
Driving home from near 58507 Lüdenscheid to 48712 Gescher.
Good results tonight:
Old 16-11-2005, 20:35   #329
Not really usefull results.
Old 16-11-2005, 21:49   #330
On the verge of winter conditions
it seems as if winter conditions are looming. Here is a screenshot showing the slowly lengthening impulse response as monitored here in Munich today.
