Old 19-10-2016, 06:17   #1036
19 Oct 2016 : BBCWS on 3955 kHz from Woofferton
<1% overall decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 2. Local K-index: 1.
06:00-09:00 UTC Planetary K-index: 1+. Local K-index: 1.
Planetary A-index: 11. Solar flux: 78. SWPC Sunspot number: 24.
200 km MUF: <3.2 MHz, 05:00-06:00 UTC.
Old 20-10-2016, 06:16   #1037
20 Oct 2016 : BBCWS on 3955 kHz from Woofferton
9% overall decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 0. Local K-index: 0.
06:00-09:00 UTC Planetary K-index: 0+. Local K-index: 0.
Planetary A-index: 7. Solar flux: 77. SWPC Sunspot number: 31.
200 km MUF: 2.7 MHz @ 05:00, rising to 2.8 MHz @ 06:00 UTC.
Sunrise 06:37 UTC.
Old 20-10-2016, 07:51   #1038
About 67% decoded audio with the DR111, telescopic antenna and powered by a GP PowerBank. The DR111 has been playing DRM for 6h45min on one charge until now.
Definitively better with an external antenna: More than 99% decoded audio with the FRG-7700 (second attachment).
Old 21-10-2016, 06:15   #1039
21 Oct 2016 : BBCWS on 3955 kHz from Woofferton
10% overall decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 1-. Local K-index: 0.
Planetary A-index: 3. Solar flux: 76. SWPC Sunspot number: 16.
200 km MUF: no data currently available.
Sunrise 06:38 UTC.
Old 21-10-2016, 07:03   #1040
Almost 99% decoded audio during the last 30 minutes of the transmission.
Old 23-10-2016, 05:44   #1041
22 Oct 2016 : BBCWS on 3955 kHz from Woofferton
32% overall decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 0+. Local K-index: 0.
06:00-09:00 UTC Planetary K-index: 1-. Local K-index: 1.
Planetary A-index: 2. Solar flux: 78. SWPC Sunspot number: 29.
200 km MUF: 05:00-06:00 UTC, 3.8 MHz min, 4.1 MHz max.
Sunrise 06:40 UTC.
Old 23-10-2016, 15:07   #1042
BBC 3955 KHz reception near Atlanta, Georgia, USA
The overnight reception - no audio decoded, max SNR 11.17 dB.
Signal strong enough to show station ID label.
Old 24-10-2016, 05:16   #1043
23 Oct 2016 : BBCWS on 3955 kHz from Woofferton
03:00-06:00 UTC Planetary K-index: 2-. Local K-index: 2.
06:00-09:00 UTC Planetary K-index: 2+. Local K-index: 2.
Planetary A-index: 6. Solar flux: 77. SWPC Sunspot number: 27.
200 km MUF: 05:00-06:00 UTC, 3.2 MHz min, 3.8 MHz max.
Sunrise 06:42 UTC.
Old 24-10-2016, 06:25   #1044
24 Oct 2016 : BBCWS on 3955 kHz from Woofferton
03:00-06:00 UTC Planetary K-index: 4-. Local K-index: 3.
06:00-09:00 UTC Planetary K-index: 3-. Local K-index: 2.
Planetary A-index: 8. Solar flux: 77. SWPC Sunspot number: 14.
200 km MUF: 05:00-06:00 UTC, 2.9 MHz min, 3.1 MHz max.
Sunrise 06:43 UTC.
Old 24-10-2016, 11:33   #1045
The overnight reception from the back of the beam - 0.02% audio decoded, max SNR 12.79 dB.
Old 30-10-2016, 06:28   #1046
28 Oct 2016 : BBCWS on 3955 kHz from Woofferton
6% overall decoded audio during the transmission.
03:00-06:00 UTC Planetary K-index: 3-. Local K-index: 2.
06:00-09:00 UTC Planetary K-index: 3+. Local K-index: 3.
Planetary A-index: 28. Solar flux: 79. SWPC Sunspot number: 12.
200 km MUF: <2.7 MHz, 05:00-06:00 UTC.
Sunrise 06:51 UTC.
Old 30-10-2016, 06:31   #1047
29 Oct 2016 : BBCWS on 3955 kHz from Woofferton
03:00-06:00 UTC Planetary K-index: 6-. Local K-index: 5.
06:00-09:00 UTC Planetary K-index: 5+. Local K-index: 4.
Planetary A-index: 17. Solar flux: 78. SWPC Sunspot number: no data available.
200 km MUF: <3.0 MHz, 05:00-06:00 UTC.
Sunrise 06:53 UTC.
Old 30-10-2016, 06:33   #1048
30 Oct 2016 : BBCWS on 3955 kHz from Woofferton
03:00-06:00 UTC Planetary K-index: 3+. Local K-index: 2.
Planetary A-index: 26. Solar flux: 79. SWPC Sunspot number: 16.
200 km MUF: <2.6 MHz, 06:00-07:00 UTC.
Sunrise 06:54 UTC.
Old 30-10-2016, 06:38   #1049
30th Oct.
Almost 49% decoded audio.
Old 01-11-2016, 05:29   #1050
31 Oct 2016 : BBCWS on 3955 kHz from Woofferton
17% overall decoded audio during the transmission, 100% from 06:50 UTC.
03:00-06:00 UTC Planetary K-index: 3. Local K-index: 2.
Planetary A-index: 18. Solar flux: 76. SWPC Sunspot number: 12.
200 km MUF: 2.5 MHz @ 06:00, 3.9 MHz @ 06:50, rising to 4.4 MHz @ 07:00 UTC.
Sunrise 06:56 UTC.
