Old 06-09-2019, 05:46   #16
5th Sep. 2019
KTWR towards Japan, logged for 13 minutes from 1042-1055 UTC. A very weak signal. Max. 9,98 dB SNR and 0,48% decoded audio.
Meta Data: 18,44 kbps, ID:1004.
Technical: Mode A/10, 2s, 16/16 QAM, P:1/0, A:1/D:0 Timestamp: Yes.
Result: Almost no decoding with the FRG-7700. Not with the DR111 either.
Old 12-09-2019, 04:29   #17
11th Sep. 2019
KTWR DRM (KTWR) towards China, logged for 33 minutes from 1025-1058 UTC. A weak signal around 23-29 dBV in strength. Max. 12,16 dB SNR and 33,22% decoded audio.
Technical data at the beginning:
Meta data: 11,64 kbps, EEP, aac, Mono, English, Religion, Guam, ID:1003
Technical: Mode B/10, 2s, 4/16 QAM, P:0/0, Audio:1 / Data:0 Timestamp: Yes
The parameters changed during the transmission !
Technical data later:
Meta data: 9,18 kbps, EEP, aac, Mono, English, Religion, Guam, ID:1003
Technical: Mode C/10, 2s, 4/16 QAM, P:0/0, Audio:1 / Data:0 Timestamp: Yes
Audio Spectrum: about 4000 Hz (both modes). Audio quality: Quite OK for spoken contents. Result: Poor to moderate reception in Japan.
Could there have been co-channel QRM? At the end of the transmission decoding became perfect (though there was no audio).
