Old 10-11-2010, 20:52   #31
Hi all DRM Plotter users,
I rearranged my web sites, so the HELP and the TX Sites updates probably did not work the last couple of days. Sorry for that. This has been fixed this evening. But the versions in use today (the ones you use at present) will only try to update from the "old" web site (.ch), the modified (latest) version (still to come) will attempt to update from both sites (.se and .ch).
Note: The present versions CAN access the (old) updates, but I will ONLY support actual updates from versions 7.0 and up of the DRM Plotter from the end of November 2010.
I recommend that you update to the latest version of the DRM Plotter from my omnirep[dot]se site. The new version (V7.0) will be uploaded towards the end of the month.
Thanks for your interest in the DRM Plotter.
Old 05-04-2011, 06:04   #32
Re Audio Percent:
Originally Posted by simone
@ Zyg: I wonder that you said that the audio was 100%, it should have caused some audio glitches too. Simone
@Simone, Oops, a bug in the DRM-Plotter! It should read 98.02%. I'll check and correct it. I used a check with FAC and MSC, and if they all are OK, I assumed the audio was 100%.
Old 05-04-2011, 08:30   #33
April 05
@ Terje,
Using Dream 1.12b and 1.14 I found, in the log file, that Latitude and Longitude are displayed in the form XXX' instead of XX0X', as in older Dream versions, like 1.6.1cvs. This leads to miscalculation of distance in the DRMPlot sw. Can this be fixed ?
File Type: txt LOG.txt (607 Bytes, 106 views)
Old 05-04-2011, 09:37   #34
Hi John,
The new DRM-Plotters takes Lat and Long from the drmplotter.ini instead from the dreamlog.txt. Could you try downloading a newer version? If you want, rename the existing folder and put the new DRM-Plotter in a new, empty DRMPlot folder.
Old 05-04-2011, 17:48   #35
April 05
Hi Terje,
I will.
Old 31-07-2018, 07:47   #36
Japanese Windows 10
Just a note regarding the DRM-Log Plotter and the DreamLog.txt file. For some reason my PC saved this file from DReaM in UTF-8 format. There is some control characters that conflict with the Plotter so that the headers get messed up. The solution (today) is to save text files as ANSI instead.
I have updated the installation procedure for Windows 10 on the Plotter Download page in Hobbyradio dot se.
Old 11-05-2019, 09:34   #37
DRM-Log Plotter V 22.0
The V 22.0 of the DRM-Log Plotter is about ready to published, but first I want to find out why W10 won't let Friedrich to open it.
