Old 02-10-2015, 13:43   #301
Oct_01
A result for 275 mins at 98.9% CDA and 31.1 dB max SNR.
Old 02-10-2015, 22:05   #302
Oct_02
239 mins at 98% CDA.
Old 04-10-2015, 07:25   #303
Two logs, one from the 2nd and the second from 3rd October, both about 290 minutes in length. Both logs with 99.99% decoded audio.
In case the audio percentage is higher than 99.995% it will become a "100%" in the Log-Plotter.
Old 04-10-2015, 22:42   #304
Oct_04
Mixed results. After 21H42 the signal dropped by ~20 dB causing decoding problems. 92.6% CDA and 33.4 dB max SNR, 197 mins log.
Old 05-10-2015, 22:41   #305
Oct_05
The signal sometimes reached 80dBuV and high SNR values recorded (max SNR 34.5 dB) but the SNR figure was changing very rapidly. A 286 mins log, 96.9% CDA. There was a period of very bad decoding.
Old 05-10-2015, 23:06   #306
AIR Bangalore India 7550 kHz reception near Atlanta, Georgia, USA
This evening's reception report - no audio decode, about 7 dB max SNR.
Old 25-05-2016, 09:13   #307
I gave this QRG at test last night, May 24 @ 21:00 UTC.
Good reception of AIR and the GOS, but all in AM.
Old 26-05-2016, 05:16   #308
Exactly one month ago I got a message from AIR that they had some spare part problems but would be back on air with DRM again soon.
Old 18-06-2016, 18:26   #309
LoTHar57
today gosIV is back on 7550khz at 1820utc Northeast France
http://imagesia.com/gosiv-18062016_18pv8
LoTHar57 is offline   Reply With Quote
Old 18-06-2016, 19:20   #310
Yes good signal SNR 22 to 23 db two Channel.
Old 18-06-2016, 19:30   #311
Good the have them back again, especially as it's their 80th birthday.
Old 18-06-2016, 22:33   #312
June_18
A 30 mins log at 99.9% CDA, the signal was ~60dBuV.
Old 18-06-2016, 23:18   #313
Having been alerted by an email from Terje, which I read only a few minutes before AIR signed off, I rushed upstairs from my supper-making to check the signal of AIR on 7550 kHz here in Eastern Newfoundland. My Morphy-Richards 27024, with its eight-metre wire attached, detected and was able to decode the labels from the two channels, but with no audio. The MER rates were too low, from 3 db to 6 dB.
I am glad they are back and I'll be checking other evenings.
Old 19-06-2016, 07:22   #314
Yes, nice to have them back again on 7550 with a rock solid carrier. At 1925 UTC the channels were labeled GOS-IV and VIVIDH BHARATI. Later the latter switched to FRENCH around 1945 UTC. There was a mode change at 2042 UTC which explains the label "MAIN CHANNEL" in John's log.
My log was set to shut down my PC automatically, but I mistook the time, so I missed the last 45 minutes.
Old 19-06-2016, 22:06   #315
This evening, Sunday 19/6/16, at 2200, I am receiving the two AIR channels with about 95% audio decoding. MER rates are between 9 and 13 dB.
MR 27024 with eight-metre wire antenna, in Eastern Newfoundland.
My Avion set (with a Sony loop "active antenna" is showing 9 -12 dB MER but is unable to decode any audio.
