Old 06-10-2010, 02:33   #16
RafaelColDRM
RafaelColDRM's Avatar
Hi all
This tonight with excellent signal on 12110 Khz from 0000, with RFI in french and spanish, after 0200 with Radio Taiwan Internacional in spanish. I was received images. You can see and more about this transmission on my DX blog
Please visit
Good DX
RafaelColDRM
Bogota D.C - COLOMBIA
http://dxdesdecolombia.blogspot.com/
RafaelColDRM is offline   Reply With Quote
Old 06-10-2010, 04:07   #17
PP5AZF-Ataliba
TDF in São José City (GG52QK)
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
www.youtube.com/atalibazf
Old 06-10-2010, 04:35   #18
Brendan1
Brendan1's Avatar
12110 from TDF Montsinery 6 Oct
This broadcast did not go as well as 17650. It began just one hour before local sunset (0100), and so got caught up in the grayline and shifting ionospheric layers. It did not get better until well after 0200, and then was not all that steady. I'd have suggested using the 31 meter band for this time slot, but oh well...
73s
Brendan WA7HL
Bellingham WA
48.763N, 122.513W - CN88rs
Airspy HF+ Discovery + SDR-Console s/w + 60m dipole
Brendan1 is offline   Reply With Quote
Old 06-10-2010, 18:18   #19
For those interested, the TDF Montsinery 17650 kHz signal is expected to gradually shift away from the US east coast from 22:00 to 23:00 UTC.
The VOACAP predicted signal strength footprint (assuming TDF is beaming directly towards Mexico City) is shown in the two attached plots.
The signal propagation is forecast to continue that shift for the rest of the evening transmission.
34°02' N, 84°24' W
Old 06-10-2010, 21:04   #20
stef
stef's Avatar
some seconds decoding,i think the tx was failing at end of log
stef is offline   Reply With Quote
Old 06-10-2010, 21:34   #21
After a good late start something happened in the ionosphere and the propagation conditions were gone. This was the same for CVC from Chile on 17640 kHz, which usually is around S9 and was 20 dB weaker this evening. So the results at 14 kbps tonight are not comparable with yesterdays reception when propagation was good. DRM ended short before 21:00 UTC and the following short AM was 100% readable.
We can compare average SNR and CDA for the three different bitrates during the same time interval 19:20 to 20:48 UTC:
kbps_____Avg.SNR_____CDA
20.96______14.7______17.46
17.00______18.4______34.41
14.56______12.2______19.79
I wonder what tonight's CDA might have been at yesterday's 18.4 dB avg. SNR!
A very interesting test!
Old 06-10-2010, 23:22   #22
Brendan1
Brendan1's Avatar
6 Oct log
Reception was very, very good until 2220 when it appears they shut down. Also had three distinct transmitter off-air periods, when it seems that analog AM was broadcast for comparison purposes (DRM-NA listserve reports). As you can see, signal strength and decoding were both excellent during the on-air periods.
73s
Brendan WA7HL
Bellingham WA
Old 07-10-2010, 00:15   #23
TDF Montsinery to Mexico 17650 kHz reception near Atlanta, Georgia, USA
Apart from the transmission breaks, etc., the best reception was between 20:00 and 21:00 hours.
34°02' N, 84°24' W
Last edited by AF4MP : 07-10-2010 at 12:11. Reason: corrected transmitter distance error on chart
Old 07-10-2010, 03:51   #24
PP5AZF-Ataliba
CVC 17.640 and TDF 17.650 - simultaneously
Duas emissoras lado a lado, sem espaço separando no espectro entre elas. Aliás, ou a frequencia de referência da CVC (17.640 khz) estava 0.5 Khz acima ou da TDF (17.650 khz) estava 0.5 khz abaixo. Somando a largura de banda total das duas rádios ficou igual a 19,5 khz onde deveria ser 20 khz.
O resultado foi que uma emissora interferiu no espectro da outra em pelo menos 500 khz.
Two stations side by side with no space separating the spectrum between them. Moreover, the frequency reference or CVC (17,640 kHz) was above 0.5 kHz or TDF (17 650 kHz) was below 0.5 kHz. Adding to the total bandwidth of the two radios was equal to 19.5 khz where it should be 20 kHz.
The result was a station that interfered with the other spectrum in at least 500 kHz.
www.drm-brasil.org
www.abradig.org.br
Youtube channel:
