Old 09-04-2011, 20:06   #1216
Testing Pappradio, only the last few minutes:
Old 12-04-2011, 20:23   #1217
CVC is down from 18kbps stereo to 15kbps mono.
Until now I had a little good audio, now I have a lot bad audio, especially with music.
In german we say: I see it with one laughing and one crying eye.
There is an "improvement" in CDA, but this does not cure the reason TX IMD, see screenshot.
The impulse response is bad and the signal strength still below S9 at this time of year.
In a month's time hopefully the propagation will be better.
Then it will be time to go back to better audio quality again.
Old 13-04-2011, 12:10   #1218
mathias_s
mathias_s's Avatar
Dear Friedrich,
I did some test with 16 QAM yesterday, because Rafael from Brazil asked me to do it. Today we will go back to good audio quality.
Mathias
mathias_s is offline   Reply With Quote
Old 13-04-2011, 20:21   #1219
Hi Mathias,
I think transmitting near FM quality is a good decision
although the comparison between yesterday and today makes me think.
Yesterday at robust low bitrate we had 99.84% CDA at 17.0dB average SNR.
Today at higher bitrate we had only 88.22% CDA although the average SNR
was higher at 17.8dB!
That means yesterday I had not so good audio all the time,
but today very good audio only during the last 25 minutes.
Old 14-04-2011, 07:53   #1220
I listened for a while last night, but unfortunately I did not get any decoded audio so I switched off after about 20 minutes. 14.x kbps with AAC+ can sound OK, I've heard that before on other stations.
Old 14-04-2011, 20:11   #1221
A little better today, signal is getting stronger:
Old 16-04-2011, 20:12   #1222
Today I think staying at high audio quality is the right decision.
CVC should try to reduce the TX ntermodulation.
Old 18-04-2011, 20:22   #1223
There was a weak period for some 15 minutes, the rest was good:
Old 19-04-2011, 20:07   #1224
Just good enough to listen:
Old 20-04-2011, 21:21   #1225
Tonight we had a line voltage outage, so the log is split into two pieces:
Old 24-04-2011, 12:27   #1226
23rd Apr.
In Switzerland we don't have much line voltage problems, but we do have some ionosphere outage problems. The last 30 minutes were the best.
Old 24-04-2011, 20:36   #1227
Getting a little better day by day:
Old 25-04-2011, 10:19   #1228
"Better" is a relative definition. At least last night's result was better than nothing...
Old 25-04-2011, 20:09   #1229
Propagation conditions are slowly improving, almost 22 dB SNR at the end:
Old 26-04-2011, 06:31   #1230
25th Apr.
Still the same situation here: The best bit is towards the end of the transmission. An unattended log.
