Old 13-05-2008, 20:36   #436
Ant-SWL
Ant-SWL's Avatar
Log start 1845 UTC.
Fading around 1906 and 1917 UTC here too. One more SNR-dip 1850 UTC. Stable the last 25 Min. with good SNR. It seems my result is in the middle between the results from Simone and Digger.
vy 73, Andy
Ant-SWL is offline   Reply With Quote
Old 14-05-2008, 20:05   #437
May 14
A log with some decoding problems during weak signal periods.
Old 14-05-2008, 20:09   #438
A short period around 19:35 - 19:40 UTC with a bit weaker signal, otherwise almost perfect.
Old 14-05-2008, 20:24   #439
Signal come up from noise 1850UTC ,low signal stringth but very good DRM signal . one mis tune of VFO 1913 !!!!!
So log 61min . perfect this evning.
Old 15-05-2008, 20:05   #440
Some problems in the beginning; the signal came and went, but between 18:07 and 19:58 UTC I logged 99.9 % CDA.
Old 15-05-2008, 20:06   #441
May 15
Some problems at the start up of the log, due to weak signal, then almost perfect until the end.
Old 15-05-2008, 20:07   #442
Ant-SWL
Ant-SWL's Avatar
Log start 1824 UTC , 92 Min. Log with 100% Audio. Very good result today.
vy 73, Andy
Old 16-05-2008, 03:55   #443
Quite good results (only logged the last 50 minutes), text messages were not working.
Old 16-05-2008, 20:05   #444
Ant-SWL
Ant-SWL's Avatar
Log start 1849 UTC. Good result. Last 25 Min. stable SNR.
vy 73, Andy
Old 16-05-2008, 20:07   #445
May 16
When the path opened then the results were almost perfect through out the transmission.
Old 16-05-2008, 20:42   #446
The thunderstorm that slowly draw nearer from Geneva added to the decoding problems. The intensity decreased 20 minutes before the end of the transmission. Thunder and DRM definitely do not go together.
Why did the SNR suddenly improve around 18:30 UTC?
In the second plot one can clearly see the lightning intensity decreasing!
Old 16-05-2008, 20:48   #447
Better conditions towards the end, still problems with the text messages.
Old 17-05-2008, 20:08   #448
No thunderstorm tonight.
Perfect!
Old 17-05-2008, 20:17   #449
Ant-SWL
Ant-SWL's Avatar
Only 42 Min. Log. Perfect result. Not a single SNR dip today!
vy 73, Andy
Old 17-05-2008, 22:42   #450
May 17
Weaker signal than yesterday but when the path opened a very good result until the end.
