Old 31-10-2005, 08:36   #1
5875 kHz BBC WS from Kvitsoy (0700- 0900)
good results using the DWT, rather long IR, no problems switching between Rampisham and Kvitsoy
Old 31-10-2005, 11:23   #2
jbriggs
James Briggs
jbriggs's Avatar
Hi Simone, Kvitsoy uses a log perodic antenna for B05, interesting to see your comment on the impulse response.
James
jbriggs is offline   Reply With Quote
Old 31-10-2005, 11:26   #3
Hi James,
here is an example what the IR from Kvitsoy looked like this morning
Old 01-11-2005, 11:19   #4
bad results today using the DWT/ DRMSWR, only an unattendended log then, so donīt know what caused the problems after 0730
Old 02-11-2005, 18:27   #5
better results using DReaM this morning, but big variations in SNR, different configuration today not using UEP anymore, seems this frequency worked much better from Rampisham in the past weeks.
Old 03-11-2005, 16:10   #6
good decoding today but results from Rampisham looked better on this frequency.
Old 04-11-2005, 10:23   #7
Nov. 4
quite good reception this morning. I stopped logging when local interference caused dropouts (in the last minute, not logged).
Old 05-11-2005, 11:46   #8
quite good and more stable than the past days using the DWT and DRMSWR, see attachment
Old 06-11-2005, 09:17   #9
pretty good results again this morning using the DWT, see attachment
Old 18-11-2005, 10:12   #10
better results at the start than the past days from Rampisham, see attchment
Old 19-11-2005, 11:07   #11
Nov 19
Good reception today from Kvitsøy.
Time: 08:44 until close down @ 08:58 UTC.
Old 19-11-2005, 11:44   #12
pretty good results this morning, see attachment
Old 27-11-2005, 10:28   #13
here is a comparison between Kvitsoy and Rampisham this morning, in the first hour some dropouts from Norway, Rampisham was perfect from 0720 but as usual only a very weak signal (-30dB) at the beginning.
Btw like yesterday it seems only Rampsiham is using the normal datastream and Kvitsoy a backup with no dataservice, textmessages, ID etc, see also different audio bitrates in the attachment
Old 29-11-2005, 15:19   #14
good results this morning still with the back up encoding, see attachment
Later today Kvitsoy was using the normal datastream again.
Old 30-11-2005, 15:17   #15
quite good after a weak start in the first minutes, see attachment
