Old 05-08-2019, 23:18   #1
KTWR 11580 kHz to South Asia
No signal at all noted here in New Zealand, August 5th @ 12:15-12:45 UTC
Had a quick look at reception on the TWR New Delhi KiwiSDR, but no decoding there either.
73 Chris
Owdjim is online now   Reply With Quote
Old 06-08-2019, 02:04   #2
KTWR (Channel 1 Audio) to South Asia with a strong signal logged for 25 minutes from 1218-1243 UTC. Max. 18,96 dB SNR and 92,22% decoded audio. At 1215 UTC there was only a co-channel interferer, a weak AM signal probably SOH Xi Wang Zhi Sheng in Taiwan (?).
18,44 kbps, EEP, AAC, Mono, English, Religion, Guam, ID:1001.
A/10, 2s, 4/16, P:1/0, A:1/D:0 Timestamp: Mon. Aug.5 12:18:00 UTC+0.
Audio Bandwidth: 5000 Hz. The audio quality was clear and very good.
File Type: jpg 2019-08-05-11580-to-South-Asia-(in-Japan)_title.jpg (29.1 KB, 54 views)
Old 08-08-2019, 05:24   #3
Today I received a very nice e-QSL card for the 11580 kHz transmission from Monday the 5th August.
Old 13-08-2019, 01:27   #4
12th August 2019
Unfortunately there was no signal at my location (central Japan) for the South Asia transmission.
Old 13-08-2019, 13:48   #5
Nothing here in NZ. Non-KTWR analogue signal here.
Old 19-08-2019, 13:59   #6
via kiwiSDR in Shenzhen South China
via kiwiSDR in Shenzhen (just a stone's throw from Hongkong), South China
Fair signal, deteriorate towards the end of program. It's a pity the first 15 minutes is in silence. Probably they forgot to switch on the audio feed?
P.S. Have to change the name of the attached "log.zip" to "log.rar" to unzip the file
Old 20-08-2019, 01:46   #7
The result (using your coordinates) was about 90% decoded audio. The DRM configuration was not Mode C as scheduled and they changed the Label to something understandable!
Old 20-08-2019, 01:52   #8
I did not expect much and that was what I got: Nothing. Except the Label "KTWR". According to their schedule they should use Mode C this week, but instead they changed to Mode B and aac+
Old 20-08-2019, 03:17   #9
Originally Posted by Digger
Thanks, Terje. I should have mentioned that the instances where SNR dropped to zero are all network related. By and large, signal is not very strong, but relatively stable.
Old 23-08-2019, 05:10   #10
alokesh
Effective 24th Aug, KTWR DRM slot on 11580 kHz to South Asia has been moved to Saturday (instead of Monday). The time remains same 1215-1245 UTC (1745-1815 IST)
Alokesh Gupta, VU3BSE
New Delhi, India.
Old 25-08-2019, 06:45   #11
24th August
KTWR to South Asia with fair signal logged for 25 minutes from 1218-1243 UTC. Max. 11,88 dB SNR and 49,05% decoded audio. Strong Chinese co-channel QRM in AM, >20 dB stronger than the DRM ruined the decoding. Metadata: 11,64 kbps, Mono, English, Religion, Guam. Tech.: B/10, 4/16, P:0/0, Audio:1/Data:0. Audio Bandwidth: <4000 Hz.
Old 06-09-2019, 06:29   #12
alokesh
KTWR DRM broadcast schedule changes
Based on comments received from listeners, KTWR has made following changes in its DRM broadcast schedule :
Effective 12th Sept, 2019 -
11995 kHz 1026-1056UTC Thursday broadcast to Japan/SK will be changed to 9900 kHz 1215-1245 UTC on Thursday.
Effective 15th Sept, 2019 -
11580 kHz 1215-1245 UTC Monday broadcast to South Asia will be changed to 15200 kHz 1026-1056 UTC on Sunday.
11995kHz 1026-1056UTC Wednesday broadcast to China will be unchanged.
11995kHz 1025-1056UTC Tuesday broadcast to Australia will remain suspended.
(Via Mika Sabin)
New Delhi, India.
