Old 04-02-2019, 06:03   #16
Hi Terje
Do you have a current schedule for AIR? What I have still indicates that broadcast is 1000-1100 UTC, but I can't find any confirmation of DRM frequencies on the AIR website.
Old 04-02-2019, 06:57   #17
Originally Posted by Owdjim
Hi Terje, do you have a current schedule for AIR?
Hi Chris,
No, I looked up the frequency in the HFCC list. It says 0945-1100. Their DRM signal is elusive - sometimes I can receive it loud and clear and most of the time there is not a trace to be seen in Dream. And when I receive it, it fades out long before 11 UTC.
Old 04-02-2019, 07:48   #18
Thanks! I see that now. Not in any "DRM" list that I can see though ;-)
I have updated my schedule database with the 0945 start time. Another 15 minutes I won't be able to receive in NZ :-)
Old 05-02-2019, 01:23   #19
I think it is pathetic that not even the DRM consortium bothers to compile a useful list of DRM transmissions!
I forgot about AIR again and started the log too late. All India Radio GOS-I logged for 31 minutes from 1013-1044 UTC. Poor propagation and a very weak signal. Max. 12,72 dB SNR and 0,68% decoded audio. The GOS-I was 10,48 kbps and the RAGAM was 8,72.
Old 05-02-2019, 10:29   #20
5th Feb. 2019
Today I remembered, but until 1030 UTC I could see nothing in Dream. Enough for today.
Old 07-02-2019, 11:06   #21
7th Feb. 2019
No traces of DRM on 15410 kHz here in Japan from the beginning until 1100 UTC.
Old 10-02-2019, 11:25   #22
10th Feb. 2019
Typical! When I thought it was no idea to log AIR and went up to have a look around 1030 UTC I noticed a strong signal. GOS-I logged for 27 minutes from 1033-1100 UTC. Good propagation and a very strong signal. The elusive AIR! Max. 23,72 dB SNR and 93,36% decoded audio.
Old 12-02-2019, 02:45   #23
11th Feb. 2019
All India Radio GOS-I logged for 48 minutes from 1011-1100 UTC. Poor propagation and a very weak signal. At the beginning around 0950 UTC there was only a carrier with 1000 Hz AM modulation. Then all of a sudden there was DRM. Max. 10,71 dB SNR and 0,01% decoded audio.
Old 14-02-2019, 06:08   #24
13th Feb.
All India Radio GOS-I logged for 67 minutes from 0954-1100 UTC. Poor propagation. Max. 15,65 dB SNR and 2,51% decoded audio.
Old 24-02-2019, 01:44   #25
23rd Feb. 2019
AIR GOS I logged for 30 minutes from 1009-1039 UTC. Not much of a signal and after 1025 UTC it faded out completely. Max. 14,63 dB SNR and 0,92% decoded audio.
Old 12-03-2019, 11:11   #26
No audio, transmission ends at 11:00 UTC.
Old 12-03-2019, 11:25   #27
Hallo Fritz,
Nice to see you here again!
Gruss aus meiner neuen Heimat!
Old 12-03-2019, 12:36   #28
Hi Terje,
as pensioner I rediscovered my old hobby.
Greetings to Japan from the dutch border.
Fritz
Old 25-03-2019, 11:25   #29
Just the last 10 minutes, transmission to AUS and NZ, 47% CDA:
Old 23-08-2019, 03:28   #30
22nd Aug. 2019
AIR GOS-I, VIVIDH BHARATI on Ch.2, both 10,48 kbps logged for 4 minutes from 1056-1100 UTC. Max. 13,93 dB SNR and 0,00% decoded audio. Just happened to stumble across this frequency after the KTWR had stopped transmitting.
