Old 04-12-2018, 10:15   #1
AIR on 15410 kHz for Australia/New Zealand
AIR continue to pick useless frequencies for their evening transmission, claimed to be for Australia & New Zealand. Absolutely no trace of the signal on 15410 kHz at "home base" at Marahau, and only 3-4 dB on the NZRDXL Northland SDRs. They really should drop the "& New Zealand" from the listing on their schedule. No-one in NZ is going to be able to receive anything.
Owdjim is online now   Reply With Quote
Old 07-12-2018, 00:55   #2
Actually got some decoding on December 6, using the NZRDXL KiwiSDRs in Northland, NZ: 4% on Main Channel and 7% on Second Channel.......
Old 12-12-2018, 06:02   #3
Originally Posted by Owdjim
AIR continue to pick useless frequencies ... They really should drop the "& New Zealand" from the listing on their schedule. No-one in NZ is going to be able to receive anything.
I actually pick up this transmission in Sweden! But SNR only around 10 dB, hence no decoded audio. On the other hand several transmissions from RRI and WINB aimed at Western Europe does not show a trace of signal at my QTH.
Old 15-12-2018, 23:14   #4
December 15th log using the NZRDXL's KiwiSDR in Northland, NZ. No sign of any signal at my home location.
Old 19-01-2019, 01:01   #5
They could drop "Japan" too . All I saw was some traces of signal including the Label.
AIR GOS1, RAAGAM on Ch.2, both 8,72 kbps, EEP, aac, Mono, English, Social Affairs, ID:1 logged for 8 minutes from 1037-1045 UTC. Max. 4,77 dB SNR and 0,00% decoded audio.
Old 22-01-2019, 07:00   #6
21st Jan. 2019
Better this time. AIR GOS1 (RAAGAM on Ch.2), both 8,72 kbps, EEP, aac, Mono, English, Social Affairs, ID:1, Mode B, 2s, 4/64 QAM, P:0/1, Audio 2/0, no time/date. Logged for 21 minutes from 1039-1100 UTC. Max. 17,20 dB SNR and 62,68% decoded audio.
Old 23-01-2019, 00:11   #7
22nd Jan. 2019
Propagation is back to poor. All India Radio GOS1 logged for 43 minutes from 1017-1100 UTC. Much less audio this evening. Max. 14,41 dB SNR and 15,59% decoded audio.
Old 25-01-2019, 07:10   #8
All India Radio GOS1 logged for 49 minutes from 1010-1059 UTC. Propagation was back, or there was no transmission last night (?). Much more (poor quality) audio this evening. First half hour with perfect decoding. The signal suddenly got much weaker around 1040 UTC. Max. 21,65 dB SNR and 71,01% decoded audio. Music in both channels around 1020 UTC. The audio in ch. 2 was distorted.
Old 29-01-2019, 02:06   #9
All India Radio GOS1 logged for 49 minutes from 1011-1100 UTC. The first 30 minutes were good, then the propagation deteriorated. Max. 22,81 dB SNR and 63,13% decoded audio.
Old 02-02-2019, 10:18   #10
This transmission continues to avoid New Zealand. So weak Dream can't even sync.
Old 02-02-2019, 11:54   #11
Feb 2
AIR with two services, neither of them with any sound at my location.
Otherwise #2, RAGAM with the label Country music could have been interesting.
Time: 10:31 until cd @ 11:00 UTC.
Old 02-02-2019, 13:00   #12
Forgot about this transmission today.
Old 02-02-2019, 20:07   #13
Medium reception from AIR of 15140 Khz this morning, poor signal, only screen no audio :
https://nsa40.casimages.com/img/2019...1118602704.jpg
https://nsa40.casimages.com/img/2019...1144343205.jpg
Old 03-02-2019, 10:50   #14
Feb 3
According to Chris excellent schedule the transmission should be 10-11.
But I started "listening" at 09:50 and AIR was on the air.
No audio, but I'm not in Australia...
I doubt that the Tx is in Nauen, which Terje's logplot shows.
Old 04-02-2019, 01:36   #15
The transmission starts at 0945 UTC. Regarding "Nauen", I suggest an update of the drmtransmittersites.txt would be helpful. The first line in the file is the date of the file. A click on "TX Sites" shows the date of the current sites list.
PS: Nauen used 15410 kHz for DRM transmissions to the German ship Andernach back in 2013.
