Old 29-10-2017, 22:35   #1
RRI on 5980 kHz from Galbeni
Hi All,
I was just listening to the 2300 GMT broadcast on 5980 kHz, which is in AM, when suddenly at 2320 it switched to what sounded like a DRM signal, which isn't listed as being on at this time.
I switched on the DRM decoder and Dream is showing this as coming from Galbeni TX1.
I'm not sure if this is a switching error, or if someone is just giving it a quick test, but if anyone sees this post before it goes off you might want to check it out.
Old 30-10-2017, 23:28   #2
Oct 30th, 2017 log ... The time of my DR111 has been off several minutes, i.e. 5 minutes in this case, for some time. Maybe, I'll remember to set it properly by the next log ... BTW, I stumbled on this frequency by accident as I hadn't seen the original post.
Very good frequency selection with a poor configuration ... RRI, you can do much better than your current configuration suggests.
Old 02-11-2017, 00:39   #3
Nov 1st, 2017 log ...
Old 02-11-2017, 06:48   #4
RRI 5980 English DRM 2330
Glenn Hauser is reporting on World of Radio that RRI is using DRM here from 2300-0000 in English.
Old 02-11-2017, 23:19   #5
No joy tonight on Nov 2nd, listened to 2330 but it was just analog.
Old 03-11-2017, 15:13   #6
2 Nov 2017 : RRI on 5980 kHz from Galbeni
Nothing was received here. During B16 there was an one hour English programme on 6015 kHz from 23:00 UTC.
Old 03-11-2017, 18:52   #7
Glenn Hauser's latest log via his DX Listening Digest mailing list gave the following, I will try and check tonight and see if this is still the case:
** ROMANIA. 5980, Nov 2 at 2330, RRI has reverted to AM, after running DRM by mistake for the first four days of B-17 during this English hour, now with classical music. With DRM I was still able to detect the JBA AM carrier from R. Chaski, PerĂº, amid the noise. Now with BFO, I hear a bit of a warble which could be caused by two carriers on slightly different frequencies, but there is no change between 2334 and 2335 when Chaski should be autocutting off. I am afraid the frequencies are too close together, and the warble may have been due to unstable ionospheric propagation from Galbeni (Glenn Hauser, OK, DX LISTENING DIGEST)
Old 03-11-2017, 23:14   #8
Nov 3rd, 2017 log which my DR111 conveniently failed to save AGAIN ... The poor logging process is one of the few problems that I have with the DR111.
The average SNR was quite good, i.e. 6+ dB with a maximum SNR ~ 9+ dB. Overall, the result was very good for my location.
Old 04-11-2017, 23:20   #9
Nov 4th, 2017 log ... nearly as excellent as 6145 kHz a few days ago.
If RRI had used a MSC of 16 QAM, I would have decoded nearly the entire broadcast ...
Old 05-11-2017, 20:24   #10
4 Nov 2017 : RRI on 5980 kHz from Galbeni
There was 99+% decoded audio during the transmission.
21:00-00:00 UTC Planetary K-index: 1+. Local K-index: 2.
00:00-03:00 UTC Planetary K-index: 0+. Local K-index: 0.
Planetary A-index: 5. Solar flux: 73. EISN Sunspot number: 0.
Sunset 16:30 UTC.
Old 05-11-2017, 23:22   #11
Nov 5th, 2017 log ...
Old 06-11-2017, 21:04   #12
5 Nov 2017 : RRI on 5980 kHz from Galbeni
There was 98% decoded audio during the transmission.
21:00-00:00 UTC Planetary K-index: 0+. Local K-index: 1.
00:00-03:00 UTC Planetary K-index: 1-. Local K-index: 1.
Planetary A-index: 3. Solar flux: 71. EISN Sunspot number: 0.
Sunset 16:29 UTC.
Old 07-11-2017, 00:10   #13
Nov 6th, 2017 log ... excellent reception for my location. If only RRI ...
Old 07-11-2017, 00:54   #14
Nov 6th at Naples, FL
Spot checked this at 2335-2345 UTC. Got the label only, Galberi TX 1. No stereo indicator so presumed mono-signal.
Hans Johnson
Gospell GR-216 and Wellbrook 1530 loop antenna.
Old 07-11-2017, 19:27   #15
6 Nov 2017 : RRI on 5980 kHz from Galbeni
There was 100% decoded audio during the transmission.
Planetary A-index: 4. Solar flux: 70. EISN Sunspot number: 0.
Sunset 16:27 UTC.
