Old 31-10-2010, 14:09   #1
BBC & DW on 5845 kHz from Nakhon Sawan
B10 schedule for this frequency:
1400-1800 UTC
This transmission is currently visible here in Germany, but due to strong utillity QRM on 5850 kHz no decoding is possible.
Old 01-11-2010, 07:59   #2
I have decoding ysterday afternoon this station no problem, but I wille this Day Screen copy, ysterday I have no screen copy.
Old 01-11-2010, 16:55   #3
Siber
Siber's Avatar
Arrow 5845kHz BBC&DW from Nankhon Sawan
Russia,Irkutsk city. Audio is dropped.
Degen 1103+ IFF 450kHz+converter 450/12 kHz, Long Wire.
Siber is offline   Reply With Quote
Old 01-11-2010, 18:14   #4
Pirx
Big QRM on 5850 kHz!
Only 50% decoded audio.
Pirx is offline   Reply With Quote
Old 03-11-2010, 15:25   #5
A utility TX 5 kHz up ruins everything!
Old 03-11-2010, 15:36   #6
Nov. 03
Not expected a better result, being in the back lobe, but here is a 69 mins log.
Old 04-11-2010, 15:21   #7
Nov. 04
Bad results and a lot of mode testing.
Old 05-11-2010, 17:37   #8
Nov. 05
No tests tonight and much better results after 15:05.
Old 05-11-2010, 18:03   #9
A few syllables elbowed themselves through to my speaker, but that was all.
Old 06-11-2010, 18:38   #10
Simply the wrong frequency, nothing else!
I tried all antenna configurations, but this 4 kHz wide datasignal on 5850 kHz is always there and steals 2 kHz of the DRM signal.
I switched to usb with reduced bandwidth and used the -E 5100 switch in DReaM.
That helped a lot, but it did not really save the day.
There were several fsk transmitters on frequency.
Testing different modes (12kbps vs. 17 kbps) was very interesting.
With 12 kbps much more bad audio was decoded than good audio with 17 kbps.
Two ways out of this dilemma:
Either QSY 5 kHz down or -not as good but certainly an improvement- QSY 0.5 kHz down and use 9 kHz mode.
Old 07-11-2010, 09:10   #11
Agree 100% except for the -E 5100 switch in Dream (did not work here).
That data churner seems to be on all the time (now: 0915). -5 kHz could be a better option.
Old 07-11-2010, 17:53   #12
Nov. 07
A 20mins unattended log, then dream crashed.
Old 08-11-2010, 18:06   #13
Nov. 08
A 3H43 log. The signal got much better near the end of log as well as the SNR.
Old 08-11-2010, 19:48   #14
Originally Posted by mitajohn
Hi all, A 3H43 log. The signal got much better near the end of log as well as the SNR.
Hi John,
congrats, no chance to get anyway near your reception results up here.
Old 09-11-2010, 18:23   #15
Nov. 09
A 4 hour log, my best so far from this TX. The results got better after 14:35. The signal reached up to 40 dBuV sometimes. Good audio.
@Fritz. Thanks my friend, but its not me but my area, which seems to be "inside" a good lobe. If there was not the QRM on 5850 kHz, I would report even better results.
