Old 02-11-2009, 06:07   #1
Radio Romania on 6020 kHz from Galbeni
The propagation in 6 MHz was not the best and the Channel Impulse Response was very messy, which resulted in very little audio. The little I caught was very distorted. Btw, the Label read "Transradio Bln" and the transmission was listed as P-Stereo with 20.96 kbps.
Old 09-01-2010, 06:00   #2
Still the Transradio Bln. label and audio badly distorted/ clipped.
Edit: Zipped mp3 audio sample attached.
Old 19-01-2010, 06:28   #3
Ager
Ager's Avatar
They have a problem that sounds exactly the same as REE did previosly. It sounded like chewing bulbs, as it was then described here.
REE did correct its configurations. Noblejas sounds now very pleasant in deed. Hopefully the same will go for Romanian Radio, too. - I, too, made a brief bulb-chewing sound sample: www.infoverstas.fi/mp3/6020.mp3. It was labeled as as stereo 20.9 kbps and
Transradio Bln!
Ager is offline   Reply With Quote
Old 03-03-2010, 09:43   #4
The "Transradio" label has been changed to "Galbeni ID 300-1". The distorted audio is still the same. The audio level is normal, it must be some other problem in the audio chain. The log was unattended. The SNR dropped for some reason I cannot explain.
Old 12-03-2010, 06:25   #5
Good signal on this freq. but audio BW for AM transmitter,
Old 28-11-2010, 06:13   #6
Good reception:
Old 04-02-2011, 06:03   #7
Unattended log:
Old 15-02-2011, 06:53   #8
Feb. 15
A bad result, although the signal was about 30 dBuV, almost no decoding.
Old 31-01-2015, 06:36   #9
Good results this morning for the German programme
Old 01-02-2015, 06:34   #10
Strong signal with a few minutes break in the middle, processed audio with strong compression not suitable for DRM.
Old 07-03-2015, 09:11   #11
The label reads Tiganesti, but the result is the usual. Only 37% decoded (German) audio.
Old 23-03-2015, 08:10   #12
Even worse this morning. Actually, nothing at all.
Old 23-03-2015, 15:27   #13
RRI have recently posted their DRM frequencies for the A-15 Season:
0300 - 0356 UTC 15220.0 kHz EE
0400 - 0426 UTC 15220.0 kHz CC
0430 - 0456 UTC 7390.0 kHz RR
0500 - 0526 UTC 7330.0 kHz FF
0530 - 0556 UTC 11800.0 kHz EE
0600 - 0626 UTC 7435.0 kHz GG
1500 - 1556 UTC 11870.0 kHz RR
1700 - 1756 UTC 11810.0 kHz EE
1800 - 1826 UTC 5910.0 kHz II
1800 - 1856 UTC 7300.0 kHz GG
2000 - 2056 UTC 9800.0 kHz FF
2030 - 2056 UTC 9800.0 kHz EE
Old 23-03-2015, 15:45   #14
We need to put all this in a new thread... Neil, please ...
Old 23-03-2015, 16:04   #15
Apologies, I should probably have done that in the first place, still finding my way around here yet. I'll create a new thread and post them again.
