Old 21-04-2006, 07:47   #1
Baldo34
Baldo34's Avatar
1593 kHz WDR from Langenberg
DRM tests from WDR station Langenberg on 1593 kHz. This frequency was in use for WDR till the end of 1993, later Radio Free Europe from Holzkirchen, now back in Langenberg.
See screenshot.
73, Klaus
Equipment: Winradio WR-G303i
DX-10 active antenna
http://www.drm-dx.de
Old 09-06-2006, 13:43   #2
Just in time for the FIFA world cup, WDR started their DRM transmissions from Langenberg today.
Currently playing classical music, high bitrate, good audio quality.
Edit: Meanwhile they are reporting from the stadium in München.
Old 09-06-2006, 18:45   #3
Here is my first report, some dropouts but great audio quality!
Interesting mix concerning the programming, classical music and reports from the world cup!
Old 10-06-2006, 07:06   #4
And here is my over night report. Quite good in darkness.
Old 10-06-2006, 09:10   #5
Here is a report from half past midnight till loss of signal in daylight.
WMER was always higher at the upper part of the spectrum, there were some problems from the channel below and during fading, an on-channel carrier could sometimes be seen. Since this is my first try on this frequency, my loop's position may not have been at its optimum so far.
See screenshot for typical spectrum, waterfall, impulse response and WMER plots.
Old 10-06-2006, 10:06   #6
Quite good results during the night even with the high bitrate, except 0000- 0030, could also be seen in Carsten´s report.
Old 10-06-2006, 12:43   #7
Only 65 km to TX, so no problem here at daytime except with local interference. Good audio.
Noise from some fluorescent tube light in the house reduced the snr in the beginning.
The programme is WDR 2 Klassik, the same (unwanted) material they had on DAB for some years until they switched to the regular WDR 2 programme......after the last DAB radios had disappeared in the shops here.
Old 11-06-2006, 06:13   #8
Thumbs down
Very sad:
In good old times they were running several hundred kilowatts in AM with a big signal all over europe, now they do not even manage to transmit a readable signal at 65km distance.
Old 11-06-2006, 08:07   #9
Really bad last night.
Old 11-06-2006, 09:17   #10
Great results last night until 2200, excellent audio quality.
Old 11-06-2006, 11:28   #11
June 10
A rather bad result last night.
Old 12-06-2006, 08:29   #12
June 11
Quite good last night.
Old 12-06-2006, 18:02   #13
MOBILE RECEPTION
Driving from 30926 Seelze near Hannover to 48712 Gescher via B441, A2, A30, A31.
Antenna pattern seems to be stronger to the east than to the north.
Boring programme material.
Old 13-06-2006, 00:53   #14
June 12
Quite good in Munich tonight, there were a few short dropouts though.
Old 13-06-2006, 17:28   #15
MOBILE RECEPTION
3 in 1:
1. Gescher - Gelsenkirchen Scholven
2. Gelsenkirchen Scholven - Muenster
3. Muenster - Gescher
