Old 10-03-2006, 08:49   #1
Baldo34
Baldo34's Avatar
Thumbs up DW Sines on 13810 kHz
I did no log, but the signal is excellent on this frequency: S 9 +50 dB !
73, Klaus
Equipment: Winradio WR-G303i
DX-10 active antenna
http://www.drm-dx.de
Old 11-03-2006, 09:02   #2
Not good this new Sines frequency. A weak and instable signal.
Old 11-03-2006, 18:49   #3
tradio99
very good results today
Vladimir
tradio99 is offline   Reply With Quote
Old 11-03-2006, 19:01   #4
Smile DW Sines 13810
Hi.
Signal is excellent on this frequency very strong S9+10db no QSB or QRM.
My log is on 42min. and 99%CDA.
Old 12-03-2006, 14:12   #5
Strong and perfect today.
Old 14-03-2006, 19:12   #6
strong signal with some fading yesterday
Old 14-03-2006, 19:16   #7
Thumbs up MOBILE RECEPTION
Driving from 48712 Gescher to Muenster on the B525, A43.
High SNR, should run higher bitrate.
Old 14-03-2006, 19:54   #8
Looks quite good. Cannot say something about the 2 drops.
Old 15-03-2006, 10:03   #9
Thumbs up 15th Mar
Very good reception. The two interruptions were A) my tuning the RX and B) a sudden TX break about 40 seconds or so.
PS: Carsten, the carrier disappeared for about 40 sec, - S0. That's why.
Old 15-03-2006, 20:08   #10
Perfect, but again one strange drop....
Old 16-03-2006, 19:28   #11
Wow, no drop today.
Old 17-03-2006, 08:48   #12
CT4RK
CT4RK's Avatar
Hi Carsten
The dropouts was caused by the antenna change, due the works on 4MHz antenna that is near of the TCA3 (normaly runing the 13810).
73 from: CT4RK
Carlos
Sines - Portugal
Old 17-03-2006, 09:27   #13
strong and stable signal, but a few dropouts at the beginning, using DWT/LA380 indoors
Old 17-03-2006, 19:17   #14
Hi Simone and all,
I think, that I had the same drops at the beginning.
Old 18-03-2006, 09:11   #15
super strong signal!!!! Receiver seems to be overloaded - low SNR, above 90 dbV even audio decoding stoped! At 8:30 I switched on a 20 db attenuator.
