Old 14-07-2015, 05:25   #166
13 Jul 2015 : RRI SNR Tiganesti 11810 kHz
80% decoded audio, which is a lot poorer than normal.
15:00-18:00 UTC Planetary K-index 4. Local K-index 4.
Planetary A-index: 11. Solar flux: 112. SWPC Sunspot number: 59.
Old 15-07-2015, 05:23   #167
14 Jul 2015 : RRI SNR Tiganesti 11810 kHz
95% decoded audio, with what looks like a 2 minutes break in the transmissions.
15:00-18:00 UTC Planetary K-index 1. Local K-index 2.
Planetary A-index: 32. Solar flux: 107. SWPC Sunspot number: 44.
Old 16-07-2015, 05:39   #168
15 Jul 2015 : RRI SNR Tiganesti 11810 kHz
92% decoded audio, which is a lot less than normal.
15:00-18:00 UTC Planetary K-index 1+. Local K-index 2.
Planetary A-index: 7. Solar flux: 101. SWPC Sunspot number: 39.
Old 17-07-2015, 05:26   #169
16 Jul 2015 : RRI SNR Tiganesti 11810 kHz
98% decoded audio.
15:00-18:00 UTC Planetary K-index 2-. Local K-index 3.
Planetary A-index: 7. Solar flux: 99. SWPC Sunspot number: 39.
Old 18-07-2015, 16:36   #170
17 Jul 2015 : RRI SNR Tiganesti 11810 kHz
99% decoded audio, there was a strange short dip in SNR and decoding half way through.
Planetary A-index: 8. Solar flux: 98. SWPC Sunspot number: 55.
Old 18-07-2015, 18:02   #171
Mikey
99.4% decoded average SNR 27.1
Mikey is offline   Reply With Quote
Old 19-07-2015, 05:56   #172
18 Jul 2015 : RRI SNR Tiganesti 11810 kHz
99+% decoded audio. The plot is only from 18:13 UTC because the Newstar receiver chewed up the first part of the log and I lost 10 minutes!
15:00-18:00 UTC Planetary K-index 1-. Local K-index 0.
Planetary A-index: 5. Solar flux: 96. SWPC Sunspot number: 40.
Old 19-07-2015, 17:35   #173
Mikey
Tonight's signal at 1700 utc too weak to decode. Not sure if the problem was propogation, reduced power or the antenna was plugged into the wrong beam. Don't think it was the first one as all other signals were were showing up as normal. Gave up in the end.
Old 20-07-2015, 05:45   #174
19 Jul 2015 : RRI SNR Tiganesti 11810 kHz
I missed the first 20 minutes, and then the Newstar then chewed up the logs, so no plot! Luckily the Morphy Richards performed OK, so I can report an average SNR of 22dB and 99% decoded audio.
Planetary A-index: 4. Solar flux: 100. SWPC Sunspot number: 52.
Old 21-07-2015, 05:55   #175
20 Jul 2015 : RRI SNR Tiganesti 11810 kHz
97% decoded audio.
15:00-18:00 UTC Planetary K-index 1. Local K-index 1.
Planetary A-index: 3. Solar flux: 95. SWPC Sunspot number: 46.
Old 22-07-2015, 05:54   #176
21 Jul 2015 : RRI SNR Tiganesti 11810 kHz
99+% decoded audio.
Planetary A-index: 5. Solar flux: 92. SWPC Sunspot number: 39.
Old 23-07-2015, 05:53   #177
22 Jul 2015 : RRI SNR Tiganesti 11810 kHz
100% decoded audio.
15:00-18:00 UTC Planetary K-index 3+. Local K-index 4.
Planetary A-index: 10. Solar flux: 88. SWPC Sunspot number: 37.
Old 24-07-2015, 05:55   #178
23 Jul 2015 : RRI SNR Tiganesti 11810 kHz
100% decoded audio.
15:00-18:00 UTC Planetary K-index 3-. Local K-index 3.
Planetary A-index: 3. Solar flux: 88. SWPC Sunspot number: 35.
Old 26-07-2015, 09:11   #179
24 Jul 2015 : RRI SNR Tiganesti 11810 kHz
99% decoded audio.
15:00-18:00 UTC Planetary K-index 2-. Local K-index 2.
Planetary A-index: 23. Solar flux: 92. SWPC Sunspot number: 27.
Old 26-07-2015, 09:19   #180
25 Jul 2015 : RRI SNR Tiganesti 11810 kHz
99+% decoded audio.
Planetary A-index: 7. Solar flux: 94. SWPC Sunspot number: 54.
